Intake compatability
Old Jun 4, 2008 | 08:44 AM
Squam74's Avatar
Squam74
Hey guys, just wanted to know if a 5.0 gt40 upper intake manifold would bolt on to a 5.8 gt40 lower? And if it does, would that just choke the crap out of the 351?
Old Jun 4, 2008 | 08:29 PM
Conanski's Avatar
Conanski
Yes, the GT40 intake pieces are compatable with one another. Choking a 351 is relative.. what heads are on it, and what intake was on it before?
Old Jun 4, 2008 | 10:15 PM
Squam74's Avatar
Squam74
I'm doing a EFI conversion on a PCM 351w for a boat. I'm going to put a GT40 lower intake on it off of another GT40 marinized engine. I'm on a budget and don't want to cough up the $ for a 5.8 upper for the conversion.
Old Jun 5, 2008 | 08:39 AM
Conanski's Avatar
Conanski
OK.. the GT40 intakes are good for over 300hp if the motor under it can flow that well. There were no 5.0 or 5.8 uppers BTW, there is only a GT40 upper, so in other words, both motors use the same upper with the appropriate lower. You'll want to measure the ports in the lower where it meets the heads and open these up to match the heads.. if necessary and there is sufficient material to work with.
Old Jun 6, 2008 | 01:32 AM
LxMan1's Avatar
LxMan1
I need an upper for my Mustang as well. I'm using an Explorer upper right now.
Old Jun 6, 2008 | 07:58 AM
Conanski's Avatar
Conanski
Internally the GT40 and Explorer intakes are identical, the only difference is one is built from tubing and the other is an aluminum casting. The GT40 intake is definitely the sexier of the two, though.
Old Jun 6, 2008 | 07:19 PM
LxMan1's Avatar
LxMan1
Yeah, That's why I want one, but they are way to pricey on EPAY. I gave $102 for mine and it definately helped. I'd settle for a Cobra upper.
