Accelerator linkage help
Old Jun 28, 2015 | 12:47 AM
DarthTainess's Avatar
DarthTainess
I'm hoping somebody here can offer me some kind of assistance with replacing the accelerator linkage on my 86 F-150. It's a 300-6 with a Carter YF, I went out and bought the 30" Cable from Advance Auto, compared it in the store to the original, and then attached everything in the engine bay. However, the problem arose when I looked under the dash to connect the cable to the gas pedal, and realized that the cable was about 1.5" too long. It may sound like a stupid question, but is this ATP replacement cable adjustable? I'm just starting to learn about these old trucks. I've replaced cables before, but I've never really spent much time around a carburetor fed engine. What am I missing here?
Old Jun 28, 2015 | 12:27 PM
DarthTainess
Nobody knows?
Old Jun 28, 2015 | 01:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E3TZ-9A758-B .. 300 I-6 Accelerator Cable - 31" long / Available from Ford.
Applications: 1983 F100 / 1983/86 F150/350 & Bronco.
Old Jun 29, 2015 | 05:27 PM
DarthTainess
I bought the ATP Y-285, which is what I find when I search for that number. It mounts to the engine side of the firewall, right?
EDIT: Stupid question, quick search revealed answer. What would everybody suggest I check that would be giving me so much slack?
Last edited by DarthTainess; Jun 29, 2015 at 05:31 PM. Reason: Posted without searching
Old Jun 29, 2015 | 06:25 PM
bcamill's Avatar
bcamill
Yes, it mounts to the engine side of the firewall. Some of that after market crap is just not correct. Did you double check the length with them both out of the truck. You may not want to do this, but some of the guys will add wire ties to take up the slack. Not what you really want to do, but it will get you driving until you figure something else out. Oh ya, wire ties by the pedal, not the carb.
Old Jun 29, 2015 | 08:17 PM
DarthTainess
I did check, they appear to be the same length. The one that was on there only worked because somebody was running it with the outer tube on the end broken off inside the spring. Every time I would press the pedal, it would kink the cable and spring in a u shape. Accelerating sounded like using a ratchet. I am curious about one thing that I've noticed. My carburetor is, as far as I can tell, a Carter YF; however, I haven't seen a throttle lever like the one on mine on a single other YF I can find on google images. All of the ones I see have what I refer to as the 'pull tab' on the drivers side of the carburetor, mine has a hole with a bolt through it, no remnants to indicate there used to be a pull tab.
Old Jun 29, 2015 | 09:22 PM
DarthTainess
Here's the two best pictures I could get of my throttle lever, apologies for my fat fingers being in the way on the second one. You can imagine the angle I have to hold this camera at to get that picture with the carb still attached.
Old Jun 30, 2015 | 08:23 PM
DarthTainess
I've done more learning today. It's a YFA, not a YF. Would that still use the same cable?
Old Jul 1, 2015 | 12:38 AM
NumberDummy
joe4law
Feb 17, 2017 11:59 AM
Robert566
20
Nov 22, 2016 10:45 AM
gdw3138
Bronco II
Jan 21, 2010 01:20 AM
72bronc
Jan 14, 2009 11:56 AM
fearfactory
Jan 16, 2005 02:11 PM
