Accelerator cable
Old Jan 10, 2005 | 04:50 PM
fearfactory's Avatar
fearfactory
Accelerator cable
I have a 1978 Ford F250 with the 351m in it, I ordered an accelerator cable from LMC and the one they gave me is the only one for 78-79 351m and it's not the right cable. I have a threaded bar attached to the accelerator pedal and I forgot what the original cable looked like cause it's been torn down for about 2yrs. If anyone know what the right cable is and where I can get it please respond back. Thanks
Old Jan 10, 2005 | 06:21 PM
Obtuse1's Avatar
Obtuse1
When I needed a throttle cable for my 79 I just went to Oreilly auto parts and they had one in stock.
John
Old Jan 10, 2005 | 07:05 PM
zwinstead's Avatar
zwinstead
The only 73-79 ford trucks that used a "Cable" were 6 cyl models. Every truck I have owned from 66-79 had the threaded rod as you describe. That was OEM equipment on them. The only trucks with a cable I had was a 1966 F100 with 300 cyl and a 1979 F-100 with a 300 6 cyl.
Old Jan 13, 2005 | 07:51 AM
Obtuse1's Avatar
Obtuse1
Unless I am mistaken it's not the engine size but the year that determines whether a cable was original equipment. I am not sure which year it was that they switched to a cable but I'm pretty sure the 78 and 79 had a cable instead of the threaded rod.
John
Old Jan 13, 2005 | 08:41 AM
KJKozak2's Avatar
KJKozak2
My 79 f150 351m has a cable going from the pedal linkage to the carb. Pretty sure it's stock.
fearfactory, I think I have a spare in my parts box at home. I can pull it out and take some pix and/or measurements tonight.
K.
Old Jan 13, 2005 | 10:18 AM
fordfury469's Avatar
fordfury469
my 79 with a 351m had a threaded rod that just pushed on the the ball on the throttle linkage of the carb.
Old Jan 13, 2005 | 11:03 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
my 78 F-250 351m has the bar style, i prefer that over the cable IMO, if you say it has the threaded bar on it, it doesnt need a cable, just a ball to snap the bar onto.......
Old Jan 15, 2005 | 03:28 PM
fearfactory
It has the rod style, where can I get the ball that connects to the rod.
Old Jan 15, 2005 | 03:37 PM
SwOkcOffRoader
you might try a carb shop, i bought a variety pack at oriellys that had several, it was more than i wanted to pay for such a little item($15), but the variety is helpfull because the holes on different carb linkages vary in size...you might even find one at a salvage yard for a few cents, it doesnt matter what type of carb as long as the throttle bar assembly is the same as yours......i believe they are all alike.....hope this helps......
Old Jan 15, 2005 | 06:22 PM
fordfury469
try ford to they might sell on or go to a junk yard and take one off of a old carb.
Old Jan 16, 2005 | 08:50 AM
mark a.'s Avatar
mark a.
I think Holley sells them separately.
Old Jan 16, 2005 | 09:22 AM
buzzbait65's Avatar
buzzbait65
a speed shop will sell them , or maybe even in the HELP section of your auto parts store......take the rod with you to match the ball size
Old Jan 16, 2005 | 02:11 PM
SwOkcOffRoader
thats the kit i mentioned above, the catch is you have to buy them in a pack for around 14 bucks if i remember correctly....i still have the rest of that pack in my toolbox, only needed the one.....
