MAP
Try this one:
Yea, MAP is a standard gauge - but this XGauge is actually better than the standard one. It has a larger range which was needed because the standard gauge tops out around 37 psi absolute (about 22 lbs of boost), which diesels have no problem doing. This one should read well beyond 22lbs of boost.
Manifold Absolute Pressure
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: PSI
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: PSI
Is your Scan Gauge set to read Standard psi or KPA ? sounds like KPA to me Map Values
KOEO=96 (14 kpa) Low=96 ( 14 kpa) High=103 ( 15 kpa) Operating Value 41-324kpa 6-47psi sorry should have left the kpa out. have you cleaned the threaded nipple in the Intake?
EP=103 (15 kpa ) low = 110 (16kpa ) high=110 (16kpa ) operating values 55-607kpa -88psi
Is your Scan Gauge set to read Standard psi or KPA ? sounds like KPA to me Map Values.
Thank you rusty, I finally got these numbers in my SGII and in the correct place and now my boost reads the same as my dash gauge. And thanks also for everyone elses help with this issue. This site and people like you guys make owning these engines much less intimidating.
Tugly
12-25-2016 09:58 AM
4x4countryboy
03-29-2012 09:07 PM
carlsson
05-15-2008 05:20 PM
