brakes
Old Jun 26, 2015 | 06:40 AM
blake8105's Avatar
blake8105
brakes
I have an 86 f250HD. I have replaced the master cylinder/booster unit, rf caliper, and both rear wheel cylinders, bled brakes and pedal still seems low. any suggestion from the experts?
Old Jun 26, 2015 | 12:02 PM
Franklin2's Avatar
Franklin2
Go to the rear and jack the truck up. Turn the tires by hand and manually adjust the brake shoes through the slot in the back on both sides. Adjust them till you can't turn the tire by hand, and then back them off till you can turn the tire but there is still some rubbing. That should do it.
The self adjusters on these trucks are notorious for not working correctly so depending on how much you drive it, you might be doing this again in about a year.
F150III
Apr 11, 2014 02:43 PM
Ongoingshow
May 23, 2010 12:25 AM
falcontamr
Nov 17, 2008 04:42 PM
Blurry94
Aug 1, 2007 11:49 PM
scbronco
1978 - 1996 Big Bronco
Jan 2, 2007 07:40 PM
