New Guy with Brake Problems
Old Nov 17, 2008 | 03:19 PM
falcontamr's Avatar
falcontamr
Hello all,
I recently purchased an '84 F-150 with a 302 (4x4). The brakes were soft with a lot of pedal travel (the master cylinder was also leaking from the rear as well a one of the rear wheel cylinders leaking).
I replaced the m/c and both wheel cylinders. The soft pedal got worse. I suspected another bad master cylinder (it was a re-built unit). I replaced it with a new one. The rear shoes have been adjusted properly, the front pads checked, and the master cylinder and brakes have been pressure bled 4 times.
Here's the current symptoms;
Good brake pedal with engine off
Pedal travels to floor with engine on
I can lock up the rear brakes if I hit the pedal hard (still goes to floor)
Pumping doesn't change anything
Any ideas what to look for? I did a search, and couldn't find anything specific.
Thanks
Old Nov 17, 2008 | 03:31 PM
Franklin2's Avatar
Franklin2
Do you hear a hissing noise when applying the brakes? If the master cylinder leaks from the rear, the fluid sometimes runs into the booster and ruins it.
Old Nov 17, 2008 | 03:51 PM
falcontamr's Avatar
falcontamr
No, don't hear any hissing. I thought the booster might be bad, but I had a better brake pedal prior to doing any repairs. That makes me think it has something to do with the repairs I made or the bleeding of the brakes. But after pressure bleeding with 12-15 psi and getting clear bubble free fluid at all four wheels, I'm leaninging towards something else.
Old Nov 17, 2008 | 04:42 PM
Franklin2's Avatar
Franklin2
Also make sure the rear brakes are adjusted correctly.
Lift the rear wheels off the ground and take your hand and roll the tire back and forth while you are turning the star adjuster wheel. Even though the shoes will rub, keep adjusting the adjuster till it locks the wheel up. Then back the adjuster off till you can move the tire again, but the shoes still rub slightly.
Sometimes you can tell if the rear brakes are not adjusted, by pulling on the e-brake. If pulling the e-brake gives you a higher pedal, then they are not adjusted right.
