1978 - 1996 Big Bronco
drum brakes...ehh
Old Dec 31, 2006 | 01:40 PM
scbronco's Avatar
scbronco
drum brakes...ehh
well i got my drums installed but now the pedal goes to the floor and barley stops the truck at a slow speed
i bled the brakes
what else?
Old Dec 31, 2006 | 10:40 PM
ubereal2's Avatar
ubereal2
Red face
Have you adjusted the rear brakes?
With the rear wheels off the ground, adjust untill you can feel the brake shoes start to touch.
Bob
Old Jan 1, 2007 | 09:12 AM
lostin90s's Avatar
lostin90s
better get repair manual and save sometime adjust the back brakes up . Remove drum the adjuster is on middle bottom the will be slot in backing plate behind it. turn and see which way the adjuster makes brakes go out (up /down ). adjust till drum fits tight .put tire on leave jacked up . now threw access slt take brake tool/flat screw driver and adjust till tire won't turn. back of till turn resistace . do other side and try out . They will wear in a short ride. If you didn't replace wheel cylinder (need to bleed system) good to go. In 3-4 weeks if you check bet could adjust more. Well good luck keep us posted.
Old Jan 1, 2007 | 10:10 AM
scbronco's Avatar
scbronco
all i had to do was adjust them and properly bleed them since i decided to buy new wheel cylindars
Old Jan 1, 2007 | 10:14 AM
ubereal2's Avatar
ubereal2
Brakes
So you didn't drive them down did you? That would be about the worst thing you can do. You'd burn the brake shoes, the hardware and ruin the new drums.
Do you have brakes now?
Bob
Old Jan 1, 2007 | 10:15 AM
scbronco's Avatar
scbronco
nooooooo i didnt drive them off. i ended up taking both sets off and redoing the whole thing and the drums slid right on...adjusted them...bled the brakes and that was it. stops on a dime and gves me ehh about 5 cents change haha
thanks alot
Old Jan 1, 2007 | 10:18 AM
ubereal2's Avatar
ubereal2
Smile
Excellent. Glad to hear that. I've lost mine before, and drove into a house. A long story.
Bob
Old Jan 1, 2007 | 10:54 AM
merlynr's Avatar
merlynr
Every Ford with drum brakes that I have ever adjusted, the adjusting wheel is turned The same direction to tighten the brakes. The adjusting wheel is turned so it would roll away from vehicle if on the ground. One side has LH threads and other side is RH. The self adjuster(if it has one) must push the serrated cog wheel down. This is my crutch for remembering which way.
Old Jan 2, 2007 | 10:13 AM
lostin90s's Avatar
lostin90s
I know which way adjusters turn . But scbronco may have not . I described fix so if he never did it before he could easily figure it out . But thanks anyways.
Old Jan 2, 2007 | 07:35 PM
merlynr's Avatar
merlynr
My post was a sort of fyi and was directed at scbronco. I used your quote because of the good info in it. Just thought I'd let someone know how I remember which way to turn it when laying under a vehicle.
Old Jan 2, 2007 | 07:40 PM
ubereal2's Avatar
ubereal2
Smile Me too
I wsa thinking the same thing. From under the thing, back or front of the thing, sobor or staggared? I like staggering.
Bob
