Electrically stumped - please help!
Old Jun 26, 2015 | 10:14 PM
greenkangaroo's Avatar
greenkangaroo
Yes, it does have speed control. I see the note you're referring to and will check my assembly again.
Old Jun 26, 2015 | 10:18 PM
greenkangaroo
You know what? I haven't put the steering wheel back on. I just put the turn indicator lever on so it would operate, but the speed control wires haven't been re-attached. If that's the problem I'll know in the morning.
Old Jun 26, 2015 | 10:24 PM
Gary Lewis's Avatar
Gary Lewis
LOL! The ground is via the brushes that are on the back of the steering wheel, so....
Old Jun 27, 2015 | 08:00 AM
Franklin2's Avatar
Franklin2
Originally Posted by greenkangaroo
There is no power at the flasher base. I know that the wire colors on the original turn indicator switch are different than the new switch I put in, tho they both have nine wires. I'll work on understanding the wiring diagram vs reality this weekend so I can answer the question about wire colors/diagram.
Thanks,
Roger
Your turnsignals will never work if there is no power at the flasher. Make sure you have the key in run when you check it.
Old Jun 28, 2015 | 10:08 PM
greenkangaroo
I knew there was a reason I felt silly sitting in the driver's seat without a steering wheel in front of me. Since that and the horn assembly grounded the turn indicator system I thought that would be the fix for sure, but I put it all back together a couple times. Still no power. I'm back to the wiring diagram, right? And checking to see if there is power to the pins on the connector. That will be the next step unless one of you know another option.
Thanks, I'll keep you posted.
Roger
Vin Man
Sep 29, 2014 08:27 PM
desperado_18_2000
Oct 17, 2013 06:27 PM
silvertonguedevil
Sep 14, 2010 08:07 PM
takid455
Sep 6, 2010 09:17 PM
