does conversion to R134A require a new compressor
Old Jun 24, 2015 | 05:41 PM
TonyfromMebane's Avatar
TonyfromMebane
Question does conversion to R134A require a new compressor
I have a 93 F-150 4x4 with 5.0 and the E overdrive transmission. I had a local shop install the Retro AC Kit and charge but no cold air is blowing. He stated that I needed a new compressor for it to work effectively? Is this true?
Tony from Mebane
93 F-150 ExCab, 5.0
Old Jun 24, 2015 | 05:45 PM
sgip2000's Avatar
sgip2000
Tony from Mebane
93 F-150 ExCab, 5.0
Not necessarily true, but many compressors designed for 134 were designed to pump more volume. The original compressor should still work, just may not get as cold. Did the shop change the oil in the compressor?
Old Jun 24, 2015 | 07:06 PM
justcruzin125's Avatar
justcruzin125
Hey, it would be a good idea to change the compressor but i doubt its nessasary. I picked one from a scrap yard so it wasnt all that much. Theres no point to change anything else. I didnt and it runs good
Old Jun 24, 2015 | 07:13 PM
wtroger's Avatar
wtroger
No need to change compressor. But I would change the drier especially if it is the original. the desiccant bag in the old ones will come apart when the new oil introduced into the system. Use either PAG or Ester oil and add a full measure.
Old Jun 25, 2015 | 07:43 AM
jas88's Avatar
jas88
Unless your compressor is damaged, your local shop does not know what they are talking about. The part that needs to be replaced "for it to work effectively" is the condenser.
Old Jun 25, 2015 | 08:25 AM
wtroger's Avatar
wtroger
On our trucks the condensers are large enough to work well with r134a. I change th drier pull the orfice tube and replace it with one for r134a. And probably the most important step is to pull as complete a vacuum as possible for a minimum of 30 mins. Moisture in a r134a system is deadly to system components.
tsbrewers
May 22, 2012 07:29 AM
Deebo
1997 - 2003 F150
21
Jul 12, 2009 11:59 PM
89frankenford
Aug 23, 2007 06:38 PM
poffutt
Mar 7, 2005 02:50 PM
smandzak
May 26, 2004 04:13 PM
