Do I need some new injectors?
Old Jun 24, 2015 | 04:14 PM
Macrosill's Avatar
Macrosill
I made some videos this morning while running some power balance test on my truck. All these were at idle. If I turn any injector off the engine misses and stumbles. As soon as I turn it back on it smooths out. Some are a bit lower on the test but does that mean they "must be replaced" or they "should be replaced" or I would not worry too much about them at this point? Sorry about the glare in the videos.
I also did a Relative Compression test.
What is your opinion?
Old Jun 24, 2015 | 04:16 PM
WatsonR's Avatar
WatsonR
I would think if I turned an injector off and the trucks idle got rought, it was doing its job.... if you turned one off and nothing I'd be worried.
Old Jun 24, 2015 | 11:37 PM
Yahiko's Avatar
Yahiko
FTE Remembers
I don't see any deep dips but #4 is not the happiest camper out there.
Looks like most settles down once warmed up.
If you look at mine you can see that #7 & #8 are unhappy.
Both were replaced this last spring. Truck runs better.
I really need to do a new scan and post the trace.
Sean
Old Jun 25, 2015 | 12:25 AM
brandonrr's Avatar
brandonrr
Those injectors don't look bad at all. They aren't the best, but definitely not ready to be replaced IMO. Trying some archoil with fresh Rotella T6 should help.
Old Jun 25, 2015 | 07:10 AM
Macrosill's Avatar
Macrosill
Thanks for your opinions guys. I will drive on and just keep tabs on them.
Old Jun 25, 2015 | 08:34 AM
CPB1's Avatar
CPB1
That's what I would do.
Old Jun 25, 2015 | 05:46 PM
Yahiko's Avatar
Yahiko
FTE Remembers
You may want to try the Archol in yours.
Sean
Old Jun 25, 2015 | 06:24 PM
Macrosill's Avatar
Macrosill
Already in there. After the oil cooler swap I put in T6 5w40 with a bottle of Archoil 9100.
big-head
Jan 6, 2016 05:26 PM
Nitrodude
Jun 20, 2015 08:45 PM
dannyboy950
Nov 4, 2014 12:53 AM
creator
Oct 22, 2014 11:11 PM
vlietracer64
Jan 26, 2011 05:13 PM
