Source for Flareside Step brackets?
Old Sep 22, 2015 | 11:33 PM
SCFlareside's Avatar
SCFlareside
Thanks for the info and pics! Very helpful and a good comparison to have online
It would be nice to have to make minor changes instead of recreating them from scratch. If you're interested in parting with them, PM me?
Old Sep 23, 2015 | 05:09 AM
Ford F834's Avatar
Ford F834
PM sent. They are yours for the price of shipping. I'm just glad I didn't recycle them and that they will go to good use.
Old Sep 23, 2015 | 08:09 AM
1986F150six's Avatar
1986F150six
Very thoughtful of you, Ford F834.
SCFlareside, you might want to give Ford F834 a "rep" point.
Old Sep 24, 2015 | 10:42 PM
SCFlareside
PM'ed you! Thanks very much, I will put them to good use. Hopefully I can return the favor or pass it on. Reps sent!
So I'm going back to your comment about the flareside bed on your truck. I saw a pic the other day of a grey truck, think it was an '87 extended cab with an '80-86 flareside bed on it... and it looked sweet. Yours didn't end up looking right?
Old Sep 25, 2015 | 01:30 AM
Ford F834's Avatar
Ford F834
Yes, I know the picture you are talking about. It is definitely a matter of taste but I think the grey Supercab looks pretty good. There were a couple flareside crew cabs that sparked my interest including this one. I think it is a good looking truck:
However, mine looked like an atrocity. Part of it is the really high (stock) F350 4x4 suspension needed to accommodate the front Dana 60 axle. It sits so high that the stock 31" tires hardly enter the flareside fender well at all. It looks weird. It would definitely need way bigger tires. The other thing is 9th generation fenders are not as deep, and have the molded in tail lights. My bed just looked skinny and atrophied behind the huge cab. To give it a fair chance I should mock it up again on the shortened frame, but I'm really happy with the look of the short styleside. As much as I love that flareside bed I just don't think it belongs behind a crew cab. I think the styleside looks better, but that is my taste/opinion. Most people who see my flareside mocked up on the crew cab just about blow milk out their nose so that is my other clue.
Here is my short styleside after the frame chop:
Old Sep 26, 2015 | 03:04 AM
Ford F834's Avatar
Ford F834
I was digging through the "Show 'em your current 80-86" picture thread looking for more freewheel shots and found this Supercab flareside creation. Maybe it just needs to be all one color to help tie it together but I'm not real crazy about how this looks either...
Old Sep 26, 2015 | 04:04 AM
Ford F834's Avatar
Ford F834
Ran across the pic of the grey truck... just so that other readers know what we are talking about...
And it looks like I'm not the only one to try a bullnose CC flareside. This is a low res pic (someone's avatar) of just that. Still kinda hard to tell how it would look on a more "normal" truck without the huge lift and specialized suspension but here it is:
Old Sep 29, 2015 | 02:50 PM
SCFlareside
We received the step brackets today - thanks again!
That pic of the grey extended cab you posted is exactly the one I was thinking of - i do think that's a sweet looking truck. It made me think about building one actually, but I see what you mean about yours. Was laughing at your "blowing milk out their nose comment" but I don't think it's that bad. A lot has to do, to your point with color and lines.
I think the flares look best from the back, side, and rear 3/4 view and worst from the front 3/4 view when the bed rails disappear behind the cab. If the paint is mismatched, it's worse... and if there is some kind of line on the bed's fenders that connects with the cab, it's better. Two tone paint or even stripes. Check out the grey flare below, the owner at some point had grey stripes on both lines of the rear fender. I think that pulls it together well...
It makes the eye go to the fender and accents the width. You know its funny how in the '80s I didn't love the flaresides, thought they looked old. Now, I consider these the last "real" flaresides and I think they look old... and classic
In the end though that styleside bed does look really good on your truck
Old Oct 2, 2015 | 05:48 AM
Ford F834's Avatar
Ford F834
That pin stripe does seem to accent the fender width. Come to think of it my bed that I pulled in the junkyard has a stripe also. It's only on the lower edge of the bevel but has a similar visual effect.
Old Oct 30, 2015 | 12:59 PM
SCFlareside
How they came out
Posting some pics here to show how we ended up modifying the pre-1980 step brackets to work with an '80-86:
Freeman Machine in Clover SC did some nice work on them - appreciate them taking small jobs like this and turning them around so quickly and well.
Spacers were added to the two mounting holes on the upper part of the bracket so that they would fit flush against the crossmember. You can see this in the first pic, the old / modified bracket is in the foreground and the '86 bracket in the background.
Then the lower surface that the step mounts to was levelled (probably restoring it to original shape actually) and slots were drilled to match the '80-'86 bracket. '80-'86 bracket is below, '78-'79 bracket is above
You can see the original look of the pieces earlier in this thread.
Once again thanks to F834 for the older version brackets!
Old May 23, 2021 | 06:57 PM
SVandal's Avatar
SVandal
There go my plans to be the first bullnose, supercab, flareside owner. Anyone know if this truck ever got a paint job?
reeltales
Nov 1, 2018 09:15 AM
sfatomartin
2009 - 2014 F150
Jan 10, 2017 11:39 AM
77FordExp
Apr 13, 2016 08:58 PM
68horses
Jul 4, 2010 09:55 AM
shortbed1
Oct 4, 2008 02:16 PM
