Not getting gas to injectors
OK guys I have to pick your brains. I parked my b2 about a year ago and everything ran fine. Now it won't start. I replaced both fuel filters and both fuel pumps I check the inertia switch I also jumper tit I checked the fuel injector relay and I also jumper to check for spark pressure tested the fuel rail and I'm getting fuel all the way up to the fuel rail however I pull the plug out and the plug is dry so where is my problem I'm not getting any fuel to the injectors
I'm not sure I understand your post. It's a bit hard to read so any additonal info or clarification you can provide would be helpful.
You're not getting fuel TO the injectors or you're not getting fuel THROUGH the injectors? What plug are you referring to - spark plug or some plug on the fuel rail?
I've had my injectors cleaned a number of times and they always tell me to use the injectors right away. If they sit for too long without being used, they can get stuck closed.
