Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Power steering problems
Old Jun 21, 2015 | 12:04 PM
lstr81's Avatar
lstr81
Have an 03 Escape / 3.0 and the steering catches when turning left. Steering wheel jerks. Replaced the pump about 2 mo. ago and seemed to help, but now it is back. Is there something else I should look at?
Old Jun 22, 2015 | 10:22 PM
scott91370's Avatar
scott91370
Are you sure all the air is out of the system? It should be by now. And if so, so you have enough fluid?
And you're sure there is nothing physically binding any of the components?
Old Jun 22, 2015 | 10:33 PM
lstr81's Avatar
lstr81
I am pretty sure all the air is out. It is on my daughters car so I am relaying what she tells me. I won't be able to look at it until Sat.
Mostly I was wondering if a rack & pinion may cause it, or an axle? Way she talks it is something binding up. I appreciate all the in put I can get.
Old Jun 23, 2015 | 07:18 AM
projectSHO89's Avatar
projectSHO89
Could be the rack, could be one of the CV joints, could be a ball joint, could be a tie rod or tie rod end.
Lots of "could be"s, it needs to be looked at by someone that is familiar with what to look for, whether that be you or a shop mechanic.
bulldog389
Jun 25, 2013 08:28 PM
brandon.edwards
Aug 24, 2012 09:30 PM
F-150_XL
May 11, 2005 07:17 PM
92aeroXLT
Aerostar
Nov 15, 2004 10:32 PM
bagman150
Aug 14, 2000 09:10 PM
