Sponsored by: Real Truck
Finding "switched power" source?
Old Mar 20, 2016 | 06:44 PM
ATP Pilot's Avatar
ATP Pilot
thanks, I found the White with Blue tracer by the Parking brake...worked perfect for my DashCam
Old Sep 1, 2017 | 03:26 AM
EMD 710's Avatar
EMD 710
Have you tried looking for what you need in the trailer wiring I believe the center/blue wire is only hot if the engine is running.
Hey has any one tried one of these plugs? you can run a power wire outside the wiring harness so you don't need to leave the key on to power acc. in a trailer or what have you. It is reversed engineered to work seamlessly with the round seven plug.
http://www.oneill components.com
Old Sep 1, 2017 | 08:01 AM
speakerfritz's Avatar
speakerfritz
use a fuse extender
pull any fuse
install the exteneder
install 2 fuses, one for the original device, one for the new device
connect your new circut to the wire on the extender
done
Old Sep 1, 2017 | 11:04 AM
Sam I Am's Avatar
Sam I Am
I went even more simple than that.
I installed an aftermarket radio in my 99 F250 SD and used the Scosche wiring kit with all the extra plugs for many different Ford vehicles. All the plugs are already wired together, they have block off plates to keep the pin end "closed" when not using that type plug.
Since all I needed/wanted was a switched power source to turn off my driving lights with the key, I very simply stuck a spade connector female on the switched power wire for the stereo and ran it through a relay to power the lights. Works great.
Old Oct 25, 2018 | 09:12 AM
ChainsandBalls's Avatar
ChainsandBalls
Originally Posted by pacnorwest
Very frustrating.
There is supposed to be a white/blue wire in the blunt cut bundle under drivers side dash.
It's even printed on the wire bundle tag as WH-BU RUN/ACC
But there is no white with blue stripe wire!
This would be the ideal place to tap into a "switch on" power source.
I've checked for power on several of the larger 18 gauge wires for power and no joy.
Should be Blue wire w/ white tracer, right?
Old Apr 26, 2020 | 07:06 AM
Venturous's Avatar
Venturous
Old thread I know but wanted to confirm on my 2015 F250 XL, in the blunted group of wires near the parking brake pedal there is in fact a white wire with a blue stripe. However, on mine, the end was under the label so I almost missed it.
I used this to power a Garmin GPS plus a monitor for a wifi travel trailer rear camera and it works as I hoped. On with key on only. It is a smallish wire so doubt it could handle a huge load, but my two gadgets combined was only 2.1 amps.
Anyway, if you cant find this wh/bu wire like the fellow above... look under the label for the end.
Old Jul 22, 2020 | 07:47 AM
iDood's Avatar
iDood
2nd Gear
Thank you.
this is exactly what I needed. You saved me a lot of hunting and pecking. Thank you.
Tim Young
6.7L Power Stroke Diesel
Feb 14, 2015 10:12 PM
Ford_Fan1
Sep 28, 2014 02:12 PM
mwells
May 20, 2014 10:28 PM
CTBob
2004 - 2008 F150
Jul 19, 2004 04:20 PM
69_bronco
Dec 23, 2002 08:30 PM
