Looking for keyed power
Old Sep 28, 2014 | 10:22 AM
Ford_Fan1's Avatar
Ford_Fan1
I am looking for some some wires that supply power when the key is turned on for upfitters in an F650 dash. I messaged Clay from RiffRaff and he suggested using wires from the customer accessory power bundle, but IIRC those wires are blunt cut in the engine bay so I am not sure how they could only work with the key on. The only wire that I know works with key on is the one that I used for my high idle switch (white wire w/ blue tracer), but I think that would have been too light to run any kind of lighting powered by a switch.
Thanks in advance for any help!!
Old Sep 28, 2014 | 11:54 AM
Edogsf350's Avatar
Edogsf350
we need pictues of the 650 dash
Old Sep 28, 2014 | 12:12 PM
Ford_Fan1's Avatar
Ford_Fan1
Lol, I haven't even ordered it yet because I wanted to make sure I could find power for all the switches first! For once, I tried to plan ahead!
Old Sep 28, 2014 | 01:15 PM
Ford_Fan1's Avatar
Ford_Fan1
I think I found a way to make it work. I just need to find one keyed power wire that is heavy gauge and use a fuse block like this. Robot Check I
Old Sep 28, 2014 | 01:37 PM
fordf150guy's Avatar
fordf150guy
You could always run your own wire off the battery into the cab and use a solinoid to switch the wire on and off. To pull a koeo low amp signal wire you could look to the radio harness or something under the hood that is only hot when the truck is keyed on to activate the solinoid.
Old Sep 28, 2014 | 02:12 PM
Rusty Axlerod's Avatar
Rusty Axlerod
All four of the up fitter switches are powered by circuits that are switched by the key. Here is some more info:
https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
pacnorwest
Jul 22, 2020 07:47 AM
prestonfletch
Electrical Systems/Wiring
Aug 4, 2016 04:50 PM
Tim Young
6.7L Power Stroke Diesel
Feb 14, 2015 10:12 PM
officer131
Jan 19, 2010 11:00 AM
Bigfwt04
Nov 15, 2008 09:24 PM
