No spark Issue
Old Jun 20, 2015 | 03:29 PM
78fourby4f250's Avatar
78fourby4f250
No spark Issue
Ok I have a no spark issue. I have spark at the coil but not at the plugs. I figured it was cap and rotor so I replaced both. I still get no spark at the plugs. I tested the plug wires with spark tester by plugging them onto the coil and plug wires are good.
I tested ICM and PIP signals and they are present.
This has me really stumped. What am I missing? Is it possible I got a bad cap and rotor? Its an Accel brand which I thought was pretty good.
What else can I check?
Thanks for any help,
Daniel
Old Jun 20, 2015 | 03:32 PM
78fourby4f250
No Spark
Sorry would probably help if I told you the vehicle specifics.
Its a 1991 F-150 with 5.8 automatic. Also has the ICM on the distributor.
Old Jun 20, 2015 | 03:48 PM
eakermeld's Avatar
eakermeld
What is the quality of the spark? Is it a lightning bolt-blue spark or a more of a static cling-yellow spark? If it is the latter, your coil may be crapping out. A weak coil will fire a plug out in the open air but with reduced intensity. It will not have enough ump to fire a plug under compression. The hotter the temps the worse it gets.
Old Jun 20, 2015 | 03:56 PM
78fourby4f250
It's a good spark. Coil is new. I have one of those inline spark testers and it lights the light up.
Old Jun 20, 2015 | 04:29 PM
eakermeld's Avatar
eakermeld
And it doesn't spark a single plug after the cap? Did you replace the wires also?
Old Jun 20, 2015 | 04:59 PM
78fourby4f250
No I put spark tester at each plug wire and no spark. Also switched out coil wire with the spark plug wires and used spark tester and it lit up so I know plug wires are good. I'm guessing I have a defective new cap and rotor. I guess I'll take it back and get another one. I'm out of things to try.
Old Jun 20, 2015 | 05:09 PM
eakermeld's Avatar
eakermeld
Yup. That would be the next step. Where is the old cap and rotor? May save you the price of another one in case that's not it.
Old Jun 20, 2015 | 05:11 PM
78fourby4f250
I still have the old one it had a lot of wear anyway so I'll still put a new one on. We'll see what happens with another new replacement.
Old Jun 20, 2015 | 05:17 PM
eakermeld's Avatar
eakermeld
Oh, I agree. But at least you will know what parts to go fetch and another new cap may not fix the problem, and it would just be a wasted trip.
Old Jun 21, 2015 | 12:37 PM
78fourby4f250
good cap and rotor
Ok I put a cap and rotor from another truck I have that runs and it still wont run. I put the new cap and rotor on the truck that runs and it ran fine.
So I know its not the cap and rotor.
Im getting really frustrated with this and if I cant get it running today its going to the shop tomorrow which I don't want to do but I need this truck running.
So what else can I check? Im at a loss here.
Old Jun 21, 2015 | 12:45 PM
eakermeld's Avatar
eakermeld
Try swapping the coil off the other truck and see what happens. After that, I have no idea.
Old Jun 21, 2015 | 01:53 PM
78fourby4f250
Ok apparently I have spark at the coil enough to light the test light but it doesn't spark a spark plug. I put a spark plug at the end of coil wire and it didn't spark the plug. So I guess its a weak spark at the coil.
What would cause that?
Old Jun 21, 2015 | 02:31 PM
eakermeld's Avatar
eakermeld
New parts don't mean good parts. Your coil is bad. Nothing caused it, the coil just died.
Jly154
25
Mar 3, 2016 07:04 PM
qman
Jul 23, 2015 09:10 PM
nbfnwe
Sep 8, 2007 07:44 PM
llehmn
Jan 1, 2005 10:07 PM
WickedPete
Aug 4, 2004 08:31 AM
