changing front axle u joints
Old Jun 20, 2015 | 03:07 PM
VROD's Avatar
VROD
has anyone done this WITHOUT removing the axles thanks
Old Jun 20, 2015 | 03:08 PM
jetdoc's Avatar
jetdoc
I don't know how you could....
Old Jun 20, 2015 | 03:35 PM
Pikachu's Avatar
Pikachu
Not possible.
Old Jun 20, 2015 | 03:54 PM
VROD's Avatar
VROD
i heard it was possible and y not thanks
Old Jun 20, 2015 | 04:34 PM
Pikachu's Avatar
Pikachu
There is nowhere enough lateral movement between the two parts of the shaft to get the joint out. Even of there was, it wouldn't make any sense to beat a joint out while the shaft is sitting in a needle bearing cage. If you remove the hub bearing unit to take the needle bearing out of the picture, there might be enough clearance, but at that point, the shaft is literally 5 more seconds to remove so you can change it in a vise or on a press.
Old Jun 20, 2015 | 06:35 PM
tjc transport's Avatar
tjc transport
i ain't rite
that is not true. you can easily remove the front u-joints without taking the axle out by simply burning them out with a cutting torch. but you can not put the new ones in without removing the axles from the housing.
Old Jun 21, 2015 | 08:36 AM
jetdoc's Avatar
jetdoc
Not to mention if the axle u joints are bad odds are the stub axle needle bearings are wasted and the stub axle needs replaced, or repaired. Cheaper to replace.
jlansaw
Sep 4, 2010 10:57 PM
Evilgt
15
Mar 4, 2010 09:48 PM
870
Feb 29, 2008 07:06 AM
RedInline6
Sep 17, 2003 12:44 AM
omni
Feb 20, 2003 10:15 PM
