Sponsored by: Real Truck
Ball joint/ axle question
Old Sep 15, 2009 | 09:35 PM
jlansaw's Avatar
jlansaw
I decided to replace my ball joints on my '03 F250 4x4 after reading all the posts that made it sound relatively simple. So far every step has challenged me, mainly because nothing came apart easy like it does on tv.
Now it's going back together and I'm having trouble reinstalling the axle, the long side. I can't seem to get the splines to engage the differential. Can someone tell me what I'm doing wrong?
Thanks
Old Sep 15, 2009 | 09:48 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Hmmm... I don't recall any real trick to get the axle splines to line up.
The long axle is kind of heavy so you might need to make sure the far end of the axle is lifted up properly to the center of the axle tube to get the splines engage.
I think just some slight twisting one way or the other should do the trick.
You'll have to drive the axle in with the same tool you installed the big seal with, so it won't just slide in.
Sorry if I'm telling you things you already know. Just trying to think of a few things that might be going on.
Good luck!
Old Sep 15, 2009 | 10:05 PM
jlansaw's Avatar
jlansaw
I didn't know if it aligned itself when it was being drove in or if you had to somehow raise that end of the axle at the same time? I can't figure out how to raise the end of the axle if that's what it needs?
Old Sep 4, 2010 | 07:14 PM
Devious69's Avatar
Devious69
Did replacing the ball joints correct the camber issue? I'm having the same problem and agree that the camber adjustment sleeves seem like a bandaid. The front suspension is so beefy on these trucks that to bend something you'd be having more problems than camber issues.
Old Sep 4, 2010 | 09:53 PM
jlansaw's Avatar
jlansaw
Yes, I replaced upper and lower ball joints on both sides at the same time and the truck drives straight and tight. Seems to have fixed the problem.
Old Sep 4, 2010 | 10:57 PM
Devious69's Avatar
Devious69
Well darn. That's both good news and terrible news. Not an easy fix and there's so much stuff you might as well do while you're in there. Thanks!
