Rear diff
Old Jun 19, 2015 | 11:34 PM
Alexcc's Avatar
Alexcc
Rear diff
So I have a 06 350 and I'm gettin clunkin from drive to reverse and now with drive too, I know my rear diff is on it's last days but I am Woundering if that could cause the clunking and now my truck around 90km shakes likes crazy and same thing wana know if that's the diff.
And if I was to fix diff myself would it not just be easier for me to just swap axles if I wanted to be cheap??
Old Jun 19, 2015 | 11:36 PM
9228.bobcat's Avatar
9228.bobcat
Check ujoints??
Old Jun 19, 2015 | 11:38 PM
Alexcc's Avatar
Alexcc
Yep and there all fine I know diff is done just need to know if that's the root cause of all the problems
Old Jun 19, 2015 | 11:54 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I would check your carrier bearing for the vibration, and grease the slip joint with Motorcraft PTFE grease to address the clunk.
Old Jun 20, 2015 | 03:19 AM
Yahiko's Avatar
Yahiko
I second the slip joint. BTW the Ford Motorcraft PTFE grease will look and feel
thin but works the best. Clean the old stuff out and apply the new to the joint
per the instructions and that should solve any slip joint clunk.
Sean
Old Jun 20, 2015 | 06:57 AM
evan1242's Avatar
evan1242
Sean
i need to grease everything again also.
can i get the PTFE grease at the local stealership?
also can i use this grease on other things like ball joints and such?
Old Jun 20, 2015 | 07:41 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Yes, you can pick it up at the dealership, but I think I also saw it on Amazon. I don't know what all the applications are for the PTFE grease, but I don't think ball joints would be one of them.
It comes in a small sqeaze tube, not in a grease gun type of tube...
Old Jun 20, 2015 | 07:52 AM
npccpartsman's Avatar
npccpartsman
Motorcraft part # XG-8. Got it from my local dealer for less than $10.
evan1242's Avatar
evan1242
gotcha. ive been using the red n tacky grease that i use on all my timken bearings at work. seems to work fine.
will get PTFE grease for that though. i think i have a small clunk also from a dead stop.
Old Jun 20, 2015 | 08:49 AM
"Phatman"'s Avatar
"Phatman"
That's amazing. I didn't know the stealership would sell anything for less than 150.00
Old Jun 20, 2015 | 03:27 PM
Misky6.0's Avatar
Misky6.0
That is not fair. I got rear brake rotors for $133!
Old Jun 20, 2015 | 03:52 PM
Yahiko's Avatar
Yahiko
The PTFE is Teflon based and should only be used on the slip
joint. You will find that it seems too thin for what it does. But
it works and the clunking will go away. Thick grease is one of
what causes it to clunk. Does not let things slide the way they should.
Sean
Old Jun 21, 2015 | 06:32 AM
lostru's Avatar
lostru
Picked mine up Friday for $7 and some change.
terrylamar
1978 - 1996 Big Bronco
Jul 20, 2016 07:55 PM
tazf250
22
Dec 2, 2009 01:20 PM
dano2010
Sep 1, 2009 07:56 PM
DouginTahoe
Mar 24, 2008 07:08 PM
nightskyisme
May 13, 2007 10:07 AM
