Y-Block questions
Old Jun 19, 2015 | 07:06 PM
Greg Rogers's Avatar
Greg Rogers
Y-Block questions
Hi Guys, I just bought a rough 56 F 100. It came with 2 engines. The one in the truck has a separate big belt that drives the fan off the crank and the extra engine has a more conventional fan that bolts onto the water pump. The one in the truck has a very small carb which looks like a 1 barrel. The extra one has a holley 2 barrel that looks like a carb you would have found on a 70's 302, it also has a air cleaner with a 292 sticker on it. Also the spare engine has a 4 speed trans with a longer shift handle than the one in the truck. I also got a extra front clip that has different inner fenders. I assume that the extra parts may be off a bigger F series truck?? How can I identify these engines? Is there a number I can look for? I assume the one in the truck is a 272 and the extra is a 292.. I am still figuring out what I want to do with this truck. I would like to put a 300 six with matching 4 or 5 speed in it but I would like to keep the floor pedals and don't know how I could make a clutch work.. Any Ideas? Thanks for your input. Greg
Old Jun 19, 2015 | 07:40 PM
Rimrock F1's Avatar
Rimrock F1
Here is a link that will tell you the casting numbers for the different Y-blocks.
TECHNICAL
Old Jun 19, 2015 | 09:49 PM
bigwin56f100's Avatar
bigwin56f100
Your truck might be a 56 but I can tell that the frame is a 53-55
Old Jun 19, 2015 | 10:41 PM
newguy399's Avatar
newguy399
Hey Kevin how just out of curiosity how can you tell it's a 53-55 frame, is the shock mounts ?
Old Jun 19, 2015 | 11:48 PM
bigwin56f100
Yep the top shock brackets are a dead giveaway, also the high mount fan set up was not used on light duty 56 trucks but was used on 54 55 so my guess is this was a 54-55 running gear with a 56 cab put on it. Check the frame rail on the pass side top for the VIN number should start F10V
Also, do the running board brackets bolt on or are they riveted on? 53-55 bolt on and 56 are riveted to the frame.
Old Jun 20, 2015 | 08:13 AM
newguy399's Avatar
newguy399
The running boards are not on right now, but I'm thinking that my frame is not a 56 cause I have the same shock mounts, hopefully the cross member I got from u will fit, will find out during week
Old Jun 23, 2015 | 07:59 PM
Greg Rogers
TECHNICAL
Thanks Rimrock, I think the engine in the truck is a 55 239 from that chart. The extra engine I still dont know Cant find the #'s.
Old Jun 23, 2015 | 08:08 PM
Greg Rogers
Yep, it is a 57 (heinz 57 that is..) The owner I bought it from told me of some "issues" . It appears the engine is a 55 239. I still havent found a vin #, but I think it is a 55 with a 56 cowl,windshield, roof and doors. It has the opening for a 55 gas tank also. It has bolted on running board brackets.
Old Jun 23, 2015 | 08:14 PM
Greg Rogers
I am thinking I have a 55 w/ 56 cowl,windshield, doors, and top. I can see welds, apparently is was done a long time ago. I will try to find the vin. Thank for the info.
Knockonwood
May 25, 2019 10:07 PM
BarePaw
Apr 28, 2015 03:15 PM
Ianmattf100
17
Nov 30, 2012 04:23 PM
matt2491
13
Nov 8, 2007 05:02 PM
Brian_B
Nov 22, 2005 02:26 PM
