trailer wiring by color/function
Old Jun 18, 2015 | 12:19 PM
RV_Tech's Avatar
RV_Tech
Are all Ford trucks the same or nearly so. You could look up pigtail adapters for controllers and get a good read on how many are the same. I know my pigtail fits a good number of models. If not using a pigtail, it is pretty easy to test individual pins or leads at the connector.
Steve
Old Jun 18, 2015 | 03:04 PM
jusjoe's Avatar
jusjoe
The more I look the deeper it gets. lol. started tracing some things out under dash. Again, the group of wires with a ford factory tag labeling them by color as brake feed, illumination, brake lamp from controller, etc. Those are kind of as I remember not exact. But apparently my 'pigtail' for brake controller? And wouldn't you know the brake controller feed and 'some other' feed are routed through a toggle switch on the dash. Flip the switch and that constant 12 goes away on blue wire. Aaaannnnddd....after replacing fuses and such, the orange is now ignition switch controlled hot wire. Things are kind of coming together, but still scratching my head on some of this.
Joe
Old Jun 18, 2015 | 03:13 PM
RV_Tech's Avatar
RV_Tech
Alrighty, so you have a switch that selectively makes wires at the rear continuously hot? Man some people have all the luck. LOL
I now have no clue. I guess someone left that switch out of my 02.
Old Jun 18, 2015 | 03:26 PM
jusjoe's Avatar
jusjoe
Yea, ain't I lucky? lol. I guess if you wanted to turn off power to controller? How much can it draw when not in use? Oh well. Time to get a controller and see what happens.
Old Jun 21, 2015 | 05:41 PM
hturner12's Avatar
hturner12
Joe
Sounds like maybe power for a backup camera on the trailer
hal101
Nov 16, 2014 10:46 PM
snyda88
All Things Towing
Oct 11, 2011 12:46 AM
apbtpetey
Electrical Systems/Wiring
13
Oct 25, 2010 10:22 PM
Supercab
All Things Towing
Jan 2, 2007 07:38 PM
jklmvincent
All Things Towing
May 21, 2004 05:22 PM
