trailer brake wiring
Old Nov 12, 2014 | 11:12 PM
hal101's Avatar
hal101
On the back of my 96 f250 their are 3 wires red blue and black
The blue has 5 volts the other 2 are zero
Do I need to add a fuse or something ?
Old Nov 13, 2014 | 09:07 PM
hal101's Avatar
hal101
Nobody can help
Old Nov 14, 2014 | 06:37 AM
bashby's Avatar
bashby
Do you have a brake controller? Blue is generally the color wire used for a brake controller.
Old Nov 14, 2014 | 11:24 AM
Freightrain's Avatar
Freightrain
Does the truck have a tow package? Is this a plug or just three wires hanging?
Yes, typically the blue is for trailer brakes. It should not have power on it without the controller activated.
Old Nov 15, 2014 | 06:36 AM
hal101's Avatar
hal101
yes it has a tow package
it dose have a brake controler that i pluged in to the plug under the dash
yes it is a plug with three wires red blue and black
all of the fuse are good i thought i should have power on the red wire
Old Nov 15, 2014 | 07:39 AM
subford's Avatar
subford
That is not a factory plug colors for the back of your truck.
A factory tow package has three plugs.
Maybe you are looking at C424 and you are calling the Black/Green wire Black the Orange wire red and the Dark Blue wire blue.
Used for the Trailer plug.
Connector 424 (4):
BK/G = Trailer Back-up lamps.
O = Trailer Battery Charge.
DB = to Brake coil in trailer wheels.
Connector 407 (4):
BR/W = Trailer marker lamps.
DG = Trailer right turn lamp.
W = Trailer ground.
Y = Trailer left turn lamp.
Used for the rear of the truck
Connector 401 (8):
LG/O = Truck rear left turn lamp.
BR = Truck rear marker lamp.
BK = Truck rear lamp ground.
O/LB = Truck rear right turn lamp.
BK/PK = Truck back-up lamp.
W/R = Truck body lamps.
W = Truck rear ground to C407.
Old Nov 15, 2014 | 03:10 PM
TobyB's Avatar
TobyB
Thanks for that!
I'm trying to sort out how someone in
the (distant) past added a 6- pin connector...
t
Old Nov 16, 2014 | 10:46 PM
hal101's Avatar
hal101
well i ran a new fuse and power wire to replace the red wire that was not hot
and now everything is working good
thanks for all of your help
hal101
zman4x4
2015 - 2020 F150
Jun 24, 2017 10:28 AM
FishOnTheBrain
Electrical Systems/Wiring
Oct 6, 2004 09:04 PM
plod
All Things Towing
Oct 4, 2004 07:31 PM
merlinke
Jan 30, 2004 08:31 PM
