L99 FRONT abs sensor 2wd ??
Old Jun 17, 2015 | 06:25 PM
Supercab's Avatar
Supercab
Wink L99 FRONT abs sensor 2wd ??
Can I replace these WITHOUT removing the rotor?
Again, Guys 2 wheel drive.
Anyone done this?
It would sure seem so.....
Thanks!
Old Jun 17, 2015 | 07:37 PM
F350-6's Avatar
F350-6
I'm pretty sure you can. I haven't done it, but if you remove the rotor the sensor is there and I don't recall any kind of retaining nut on the rotor side that has to be removed first. Just the square probe part of the sensor sticking out is what I remember. Should unbolt from the back side.
Old Jun 17, 2015 | 10:14 PM
Supercab's Avatar
Supercab
Yes, It is held in by a small bolt from the back, I just wonder if the sensor has to be oriented a particular way?
I've never replaced 1 before either.....seems that the sensor would have to enguage the teeth in the rotor somehow......
I'm in the middle of a MAJOR front brake job (replacing everything with new) and have had an ABS light on for a while traced to the front, so with 142k on a 16 year old truck I just ordered new sensors for both sides......getting OEM Motorcraft from my local Bennett Auto Supply!
Old Jun 17, 2015 | 10:15 PM
Supercab's Avatar
Supercab
Chris-Just noticed your mileage!! 510k and counting!! WOW!! fantastic!!
Old Jun 18, 2015 | 09:01 AM
timmyboy76's Avatar
timmyboy76
i knew us 2wd drives had ABS, (its saved me a few times), however, whats then the harness plug on each side of the wheels, thats pinned up against the backside firewall?...plug for 4wd?
Old Jun 18, 2015 | 12:06 PM
Supercab's Avatar
Supercab
Wink
Timmy, I have no real idea what you are saying...........
Old Jun 18, 2015 | 12:32 PM
timmyboy76's Avatar
timmyboy76
Super..theres 2 dormant plugs 91 at each side) to the rear of the front fender wells, pinned up/hanging, from the frame. Always thought they were for abs, lol..was just wondering what they were for...
Old Jun 18, 2015 | 06:53 PM
F350-6's Avatar
F350-6
4 wheel abs was an option up to 02 I believe when it became standard. I ordered it on my 99, and it was standard when I got my 02.
Old Jun 18, 2015 | 06:57 PM
F350-6's Avatar
F350-6
Old Jun 18, 2015 | 08:44 PM
Supercab's Avatar
Supercab
Well Guys, Evedentally someone ordered MY L99 with ABS!!
I ended up getting actual MOTORCRAFT replacements from my friends at Bennett Auto Supply, they went in pretty easy.....I DID unbolt them while I had the rotors off, and ended up tapping on them to knock them through.......they were kinda tight, but they came out nonetheless, my MAJOR front brake job is complete, just need to bleed in the AM!!
Old Jun 18, 2015 | 08:45 PM
Supercab's Avatar
Supercab
Chris 142k on my L99......I can only hope to get to where you are someday!!
ex0r
Escape & Escape Hybrid
Apr 10, 2017 07:49 AM
lwbdriver
13
Nov 24, 2015 06:18 AM
lovemyexpy
Mar 11, 2008 08:17 AM
nicksgt
Jan 13, 2007 08:31 PM
umtigers
Oct 11, 2005 10:57 AM
