Front shackles
Old Jun 23, 2015 | 07:39 PM
  #31
Bruinzfan's Avatar
Bruinzfan
Originally Posted by LivingLarge
Looks great Keith, they may settle a little bit but don't think 1/2 inch on that one side. Don't forget to go back and check your bolts in a few days. If it really bothers you, ride with a fat chick on the right side
It must be really off when I'm in the drivers seat! LOL I didn't even think to give the bolts a check again. Do you know the torque by any chance? Can I do it with the vehicle weight on them? Thank you!!
Old Jun 23, 2015 | 07:45 PM
  #32
Bruinzfan's Avatar
Bruinzfan
Now to look for an effective but reasonably priced Cold Air Intake that I can sneak by the DW. I was informed tonight..."I hope your done! We have spent an awful lot of money on that truck!"
Thanks for the input and the help along the way guys. As we all know it's awesome to have this community and knowledge base at our fingertips!!!
"Comparing Trucks is the G rated version of comparing swords" ~Said by someone. LOL
Old Jun 23, 2015 | 07:47 PM
  #33
LivingLarge's Avatar
LivingLarge
I didn't save the torque numbers but I'm sure someone will post it here.
BTW the ONLY way to torque the suspension is with all of the trucks weight on it. If this was done on a lift it is possible that they will settle straight after a few potholes.
Old Jun 24, 2015 | 05:20 PM
  #34
IMASAP's Avatar
IMASAP
Keith, I know you were concerned that all that beer you brought up here would not be put to good use. Thought I'd post up some photographic evidence that it is being used for it's intended purpose !!
(Please use a designated driver when enjoying adult beverages near your Excursion, and please drink responsibly... like me !)
Old Jun 24, 2015 | 09:33 PM
  #35
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
I'm gonna go ahead and say used properly doesn't involve 5 inches of foam when poured...
Bruins, save your money on the CAI - the intercooler negates any benefits
Old Jun 24, 2015 | 11:32 PM
  #36
Bruinzfan's Avatar
Bruinzfan
OUCH!!!
Scotty glad your enjoying!! Thanks again!!!
Keith
Old Jun 24, 2015 | 11:38 PM
  #37
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Double check the height on your plow mount, I need to double check the DXT height specs but the VXT is 15 1/2" at the center of the eye. If not it will make the blade not sit level, You may need custom drop brackets depending on how low you need to go, looks like you could go down one more bolt hole before needing it. Wanted to mention this before you go to hook it up this fall and things are not fitting as they should.
Old Jun 24, 2015 | 11:48 PM
  #38
Bruinzfan's Avatar
Bruinzfan
Here she is with the blade on it after the shackles. I am quite pleased!!
And the front spring height seemed to even off quite after driving a bit today including some very harsh bridge expansion joints that are exposed due to paving near my house. Not to mention she got worked today. Hauled a Yard of crushed stone, (Yes in a trailer) LOL
And several blocks for the fire pit. My work in progress patio!
Keith
Old Jun 25, 2015 | 06:03 AM
  #39
Bruinzfan's Avatar
Bruinzfan
Thank you for the heads up. I will check that out today.
Keith
egreco79
Feb 19, 2014 03:00 PM
bebeard
Mar 19, 2012 10:18 PM
dillinewton
18
Jan 24, 2010 08:18 PM
muffdr
Jan 11, 2005 08:53 AM
DougD
Feb 27, 2004 11:57 PM
