boost issues or transmission problem?
Old Jun 16, 2015 | 09:22 PM
abdiverca's Avatar
abdiverca
I have a 2001 f 350 7.3 diesel r 400 tranny 320000 miles. . Im having transmission issues. It makes a slight whine/ grinding noise only in first And reverse. And it surges. Sometimes its fine though to. Check engine light came on. Only codes i get are #4 glow plug out and a low boost pressure. Checked boost before fixin Running fine at the normal about 20 psi. ive read a bad or dirty map or iat sensor can cause transmission issues along with the low boost error code. But in my experience and some reading it sounds like a stall converter. Any advice???
Old Jun 17, 2015 | 04:15 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't understand what you mean about a stall converter. Every torque converter ever built is a stall converter. They all have a stall speed.
Low boost will cause transmission problems. The first rule of fixing ANY transmission problem is to fix any engine problems first. This often fixes the transmission, too.
Old Jun 17, 2015 | 04:24 PM
abdiverca's Avatar
abdiverca
Yes torque converter. I used the Wrong words. Yes thats what i figured. Ive already started. But Boost is fine. I suppose i need to go thru all my intake sensors as well. Thanks
Old Jun 18, 2015 | 08:37 AM
Tugly's Avatar
Tugly
Originally Posted by Mark Kovalsky
...Low boost will cause transmission problems....
Whuh? Are we talking boost from the turbocharger on the engine? I spent a lot of time under the hood and never saw any connection between air in/out and the transmission. I acknowledge low boost makes heat, and transmissions probably have a distaste for a lot of heat up front - but I'm confused on the direct correlation.
Old Jun 18, 2015 | 09:14 AM
Mark Kovalsky
The direct correlation is that the shift schedule and pressure schedule is programmed for a certain output of the engine. If the engine isn't making the power it should be making you will press the go pedal further than normal. The shift and pressure schedules now see that you're further into the pedal, so the upshifts will be delayed and at too high of a pressure.
There is no direct mechanical connection between the air in and out and the transmission, but there is a programming connection.
Old Jun 18, 2015 | 09:59 PM
Tugly's Avatar
Tugly
Got it. Thank you.
Old Jun 19, 2015 | 10:08 AM
BadDogKuzz's Avatar
BadDogKuzz
Mark I often wondered what info from the engine the pcm used to effect the shift strategy and TC lock up. Does the pcm use TPS, EBP and MAP to determine how to effect shift strategy ? I figured that if anyone would know what parameters the 4R100 used to determine shift strategy it would be you. I ask because on my trans I sometimes get a VERY hard 3-4 shift and it only happens sometimes and it seems to happen when I have the fuel pedal at 80% or better. So I was wondering if EBP (preload on turbo), maybe lower boost than it should have per the EBP and TPS effected shifts?
Mind you have no codes but I might have a slight up pipe leak because I can only get 22psi boast.
Old Jun 19, 2015 | 04:55 PM
Mark Kovalsky
It uses almost all of it's sensors at one time or another to schedule WHEN to shift, and how much pressure to use for each shift.
The WHEN to shift is mainly pedal position and vehicle speed. This can be modified by temperatures (engine and trans,) vehicle acceleration rate, rate of change of the pedal, etc.
The pressure used is determined both from hard coding and an engine torque calculation that is made from injector pulse width and mass air flow. It can be modified by conditions, too, but I didn't work a lot with this calculation. That was someone else's responsibility. I just used the output of the calculation.
EBP is probably in there. It might not be a direct input to the torque calculation because the effect of the EBP is going to reduce the mass airflow through the engine, so if the EBP is restricting flow it's accounted for there.
An exhaust leak before the turbo can cause harsh shifts at higher boost levels. If the boost isn't what it should be the engine isn't making the torque that is expected. The torque calculation will correct for it, but it has limited authority. The hard coded porting of the pressure is going to be too high and that will cause harsh shifts.
Old Jun 20, 2015 | 04:47 AM
Tugly's Avatar
Tugly
...EBP is probably in there....
The shift calculation has been the cause of great speculation and consternation. I look at the data and felt my own truck with a faulty EBP (everything else 100%), and something is going on there.
Old Jun 20, 2015 | 08:53 AM
BadDogKuzz's Avatar
BadDogKuzz
Thank you Mark for sharing your knowledge on the subject. You answer has been very helpful to me. Because in my case I was thinking or hoping it was due to boost levels being alittle lower than it should be per EBP. Also I think it could be the TPS is giving the wrong input. But thank you for confirming and helping me get a better idea of what effects shift strategy.
But it doesn't seem to be as clear cut as I hoped but it does back up the fact that the engine & sensors need to be 100% for the trans to work correctly.
Eppidemic
Aug 5, 2018 05:30 PM
F33lmywrath
Jan 25, 2017 06:51 PM
olguin_12
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Feb 29, 2016 11:38 AM
Will Bite
Feb 23, 2014 02:09 PM
bigpowerstroke
Jun 2, 2007 01:51 PM
