Sponsored by: Real Truck
Best obd tool/reader
Old Jun 16, 2015 | 03:20 PM
ZekeD's Avatar
ZekeD
Ok, I'm going to break down and buy an OBD tool for my 2004 F350 diesel. Any opinion on which is best? I don't want to spend over $200 unless there is a VERY good reason.
Thanks
Zeke
Old Jun 16, 2015 | 04:13 PM
RV_Tech's Avatar
RV_Tech
Subscribing
Old Jun 16, 2015 | 04:31 PM
eazmo's Avatar
eazmo
Originally Posted by RV_Tech
Subscribing
I'm also following
Old Jun 16, 2015 | 05:05 PM
onadraw's Avatar
onadraw
My opinion is you will have to spend more than $200 to get "The Best".
If not, I think you can spend considerably less than $200 for a decent generic OBD Code Reader.
Old Jun 16, 2015 | 05:10 PM
onadraw's Avatar
onadraw
Many will say https://www.autoenginuity.com/ is the best non-factory scanner. I got the factory NGS scanner. Both are a bit more than $200.
Lots use the Torque app with an inexpensive Bluetooth or WIFI OBD plug. This is considerably less than $200
Old Jun 16, 2015 | 05:37 PM
edjunior's Avatar
edjunior
I just got an ELM-327 wireless/bluetooth unit with the free Forscan software, and I gotta tell you, I'm pretty impressed. It could be information overload...or as one guy on the other site said, "Analysis Paralysis". It works with Windows, iXxx, and Android. The interface was only $20 or so bucks from Amazon. Not bad for what you get.
Old Jun 16, 2015 | 05:49 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Writeup on OBDII monitors:
https://www.ford-trucks.com/forums/1...eral-info.html
I plug for DashBoss and Edge Insight CTS. I have a ScanGauge and it's not used hardly ever.
Old Jun 16, 2015 | 06:24 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
That is a great write up that he did on the different monitoring devices out there.
Very much worth reading.
I use the Scangauge II as my daily driver.
I also have the Torque APP Pro. It does a better job on DTC's than SGII.
The downside for me on the Torque APP is getting it connected every time I got in the truck. Also, the time it takes to "Boot up". I would have missed my failing FICM. In the 10-12 seconds it takes for the Torque APP to boot, my FICM would read 47v.
I can't speak for DashBoss, but I would imagine it having the same delay.
Scangauge II is instant. It did catch the failing FICM. I could see it go from 40v to 48v. As time progressed, it got down to 30v. It would still only take 10-12 seconds to get to 48v. And once the engine was warmed up, the FICM read 48v the rest of the day.
I have the Xgauge DTC in it. And I check it from time to time to tell me if I have a "Soft Code" or not.
Does anyone know if the other three will show if there is a soft code appearing? A specific PID that can be set up on the screen?
Old Jun 16, 2015 | 06:30 PM
ZekeD's Avatar
ZekeD
Thanks guys.
As I said I have the luxury of a Banks IQ system at gives me the basics And data output. Im looking for something more detailed........hmmmm
Old Jun 16, 2015 | 09:22 PM
Bently_Coop's Avatar
Bently_Coop
Do you have gauges or any monitor?
I have a Scangauge and I like it for my needs, however I am not in a diesel.
Old Jun 18, 2015 | 05:29 PM
Kuhntech's Avatar
Kuhntech
I like my ScanGauge II. About $150 and can be used on more than just your truck.
That can be a good and bad thing. Don't know how many neighbors, relatives, friends, etc have hit me up to check or clear codes.
ChRoNo16
May 30, 2016 08:17 PM
sand_fiend
Oct 1, 2011 12:56 AM
mrplow
Computer Chips & Tuners
Feb 3, 2004 11:34 AM
nightri1
Sep 15, 2002 11:18 PM
