fuel pump wont stop priming
Old Jun 15, 2015 | 05:04 PM
milkcartonkid's Avatar
milkcartonkid
Hey everyone, I have 91 f250 with a 351w in it. Dual tanksim having alot of trouble. My fuel pumps wong stop priming, I turn my key on and it doesnt shut off til I turn my key off. And ihace power going into my distributor cap but nothing coming out of it. It all happened after I used barsleak to fix a radiator leak.
Old Jun 15, 2015 | 05:43 PM
Conanski's Avatar
Conanski
And let me guess, no matter how long you crank the motor it won't fire? You have one of 2 possible problems and it's the second one if the engine doesn't fire. Either your fuel pump relay is stuck closed or the driver for the fuel pump circuit in the PCM is shorted, and if that happens the computer won't allow the engine to start and it(the PCM) has to be replaced.
Old Jun 15, 2015 | 05:57 PM
milkcartonkid
Is the pcm the eec?
Old Jun 15, 2015 | 06:00 PM
milkcartonkid
It doesnt fire. It cranks but wont start. Where is the pcm located at?
Old Jun 15, 2015 | 08:50 PM
Conanski's Avatar
Conanski
Originally Posted by milkcartonkid
Is the pcm the eec?
Yes, and it's located in the drivers side kick panel, to remove it disconnect the wiring harness in the engine bay first(after disconnecting the battery) and then pull the computer out from inside the cab.
Rus01
Oct 23, 2010 05:41 PM
feirmeoir
Dec 8, 2004 10:38 PM
Makchell
Nov 21, 2004 09:17 PM
absouloote
Aerostar
Jun 9, 2004 04:43 PM
78f3504x4
Apr 30, 2003 09:01 PM
