Changed oil, no start
Old Jun 14, 2015 | 09:33 PM
Dirtscooter250's Avatar
Dirtscooter250
I have had a 7.3 for many years now and know a little about the motor. I have searched and can't find any issue like this one. I changed my oil this afternoon and when i tried to restart just cranks.
-No smoke out exhaust
-Batteries at 12.2 volts
-Hpop within .25" of top
-Fuel pressure on cranking
-Pcm sends ground and activates GPR
-IPR pluged in
-Check engine flashes for fraction of second when key cycled on (normal)
-No tach movement on cranking
-Oil pressure gauge registers pressure 5 seconds after initial crank
-grey cps
-anti theft blinking while cranking
-tried unplugging icp and cranking (found this odd, normally with the icp unplugged it will trigger a check engine immediately when key is turned to on. This time, it will not throw a check engine at all). Does this sound like a bad pcm??
Truck ran fine when i parked for an oil change!
Old Jun 14, 2015 | 09:53 PM
rusty1161's Avatar
rusty1161
No tach movement, I would try a new CPS. And charge those batteries or have them tested.
Also, check your IPR connector. I had a no start last fall and mine had the insulation eaten away by oil/fuel leaks, shorting out the wires. I replaced it and all was good.
Rusty
Old Jun 14, 2015 | 11:11 PM
Don Naslund's Avatar
Don Naslund
there isn't enough information to diagnose your engine. I had a running engine, turned it off and it wouldn't restart. There are specific tests and readings that are needed to figure out what the problem is.
Old Jun 14, 2015 | 11:15 PM
Dirtscooter250
Has a new ipr and icp pigtails installed last fall. I have not had a chance to probe the icp to see the voltage readings. I cannot do a buzz test as it was built late 94 and i never had the pcm reflashed to allow obd2 communication so it wont communicate with autoenginuity. Trying to think of another way to check pcm/idm. In the mean time will try a new cps as suggested!
Old Jun 14, 2015 | 11:24 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
I would change the cps.
Old Jun 15, 2015 | 12:41 AM
stainlessstroker95's Avatar
stainlessstroker95
If the cps doesn't fix the problem, take the oil filter back off and see if the bypass valve is still on the filter base.
Old Jun 15, 2015 | 12:47 AM
madpogue's Avatar
madpogue
Did you try following the procedure in the owner's manual for disarming the anti-theft?
Does the oil pressure gauge eventually move if you crank the engine for long enough?
Old Jun 15, 2015 | 08:58 AM
97-psd's Avatar
97-psd
Since the tach is not moving I vote for cps. If that doesn't get it I would check the fuses to see if any have blown
Old Jun 15, 2015 | 09:55 AM
Dirtscooter250
Here is what I did this morning:
-I removed filter and bypass was intact. It is the staked version but was seated fully.
-I unlocked the doors using the fob so security should be disabled
-ordered cps, should get this afternoon
-oil pressure registers on gauge while cranking within 5 seconds
-all fuses good
-pcm diode good
I will update when cps is changed out!
Old Jun 15, 2015 | 09:57 AM
MOOSE_MACHINE
Everything looks good. Cps is the most likely culprit and you should always have a spare in the glove box
Old Jun 15, 2015 | 09:23 PM
Dirtscooter250
Bad news still.
-cps changed for new Ford one
-tach still doesn't move
-removed and cleaned ipr
-hpop was empty?!
-rechecked all fuses
-stumped on this one!
Old Jun 15, 2015 | 09:32 PM
stainlessstroker95
Did you try to refill the hpop?
Old Jun 17, 2015 | 03:04 AM
pilgrimbizket's Avatar
pilgrimbizket
You said it was full in your initial post
Old Jun 17, 2015 | 06:30 AM
fordman67's Avatar
fordman67
When the IPR was removed it drains the resivour.
Refill it manually. Check system voltage while cranking. It must be 10.5 or greater while cranking or it won't Starr.
Also unplug ICP and see if it start.
Old Jun 22, 2015 | 10:09 PM
Dirtscooter250
Another update.
-replaced IPR
-filled hpop, will register pressure on gauge within 3 sec
-no smoke
-tried disarming with key (no difference)
-fuel bowl full, 35psi
-oil full
-batts go to 11.5 volts while cranking
-no rpm on tach
-tried new PCM
-no chip on either pcm
Still no start. So brand new ipr (alliant), new cps (Ford), new pcm, full hpop, good batteries, wait to start light, check engine proves out and no start!
