Crankshaft Timing
Old Jun 13, 2015 | 09:22 PM
troy676's Avatar
troy676
Crankshaft Timing
I'm in the process of installing studs on my '04 6 liter and I keep reading about having the crankshaft dowel pin at 6 o'clock, I never heard as to the reasoning for this. I even went to the dealer here in town, and they just said Major engine will occur if you don't have the pin at 6 o'clock. I know why now, None of the pistons are at TDC so there's room for valves when reinstalling the heads.
Old Jun 13, 2015 | 10:03 PM
Yahiko's Avatar
Yahiko
That is the point where all the valves are not fully open
if not already closed. The reason you do that is to not bend
a pushrod if you have one that is not seated correctly.
Most of the guys will hand turn the engine over between
each torquing step to check the pushrods to make sure
they are still installed correctly.
Also after you last step hand turning the engine a full 720º
or more to make sure all is in order is a good step to make
as the last one before you sping with the starter.
Hope that helps clear the question up some for you.
Sean
Country705
Aug 31, 2009 07:00 AM
poffutt
1997 - 2003 F150
Nov 16, 2006 09:30 AM
snowboundwithoutit
17
Sep 20, 2006 10:58 AM
TallPaul
Oct 13, 2004 04:27 PM
Goffjb
Apr 24, 2004 01:58 PM
