Off a tooth?
Old Jun 11, 2015 | 01:16 PM
RIKIL's Avatar
RIKIL
Off a tooth?
If I installed my distributor and I am off by a tooth, what will be the behavior of the motor? I assume this won't be good but I also don't know...if I am off a tooth will the PIP pick this up and send the correct signal to the PCM for timing? I am thinking not because the position of the dizzy is not correct in relation to the cam.
Old Jun 11, 2015 | 01:33 PM
jaagen's Avatar
jaagen
If your that concerned you could always restab it the correct way.
Old Jun 11, 2015 | 02:52 PM
rla2005's Avatar
rla2005
As long as you can still swing the distributor to set the base timing to the correct value (10 BTDC is factory), you are good.
sgauvry
Jul 29, 2015 05:28 PM
swall
Apr 28, 2015 11:34 PM
jb_man
Jun 28, 2013 09:57 PM
RIKIL
Nov 18, 2011 09:57 AM
Redone
Jul 31, 2003 02:04 PM
