no engine change when tps is unplugged?
Old Jun 9, 2015 | 11:24 PM
tmill28's Avatar
tmill28
hey fellas, I got a 95 f150 5.0 maf and ive been battleing a rough idle dying situation. long story shot when I unplug the tps nothing changes. also when I take the vacuum line of the fuel pressure regulator the truck runs better. any ideas?
Old Jun 10, 2015 | 12:04 AM
meangreen92's Avatar
meangreen92
Can you scan it for codes?
Old Jun 10, 2015 | 08:25 AM
rla2005's Avatar
rla2005
X2....check for codes, quit poking a stick at it and guessing.
Old Jun 10, 2015 | 12:00 PM
subford's Avatar
subford
Did you mean IAC Valve and not TPS?
Old Jun 10, 2015 | 04:17 PM
tmill28's Avatar
tmill28
yea I don't care about codes, I keep getting different ones evertime I scan it. im pretty sure I need a pcm. that's why my title says no engine change when tps unplugged and not rough idle problem. all I wanna know is if the idle should change with the tps unplugged and when it is if I hit the gas it accelerates normal
Old Jun 10, 2015 | 04:47 PM
timbersteel's Avatar
timbersteel
If your getting odd and almost alternating codes, then I would pull the PCM.
Had same problem with mine with unplugging the TPS.
If you get lucky now, the PCM may be salvageable.
Old Jun 10, 2015 | 06:18 PM
Conanski's Avatar
Conanski
No change when the TPS is unplugged means the computer is completely ignoring it which isn't good, either the sensor is totally fubar or the computer is.
Old Jun 11, 2015 | 07:17 PM
tmill28's Avatar
tmill28
my guess is the computer, that's what I wanted to know. the previous owner has a superchips on it and it ran just like it does now, horrible and dies. found that took it off it was fine for 3 weeks and back to the same issue. took it out no bad capasitors but it does say remanufacterd on it, and it gets super hot even just resting on the wheel well while the trucks running. I just wanted to make sure it was that before dropping 200 for a pcm. all the junk yards by me just have non mass airflow or obd2 computers. thanks guys for your post very much appreciate it! GO FORD!!
Old Jun 11, 2015 | 07:23 PM
subford's Avatar
subford
Deleted Deleted
Old Jun 11, 2015 | 07:28 PM
tmill28's Avatar
tmill28
what do you mean? I got one from the same truck that's wasn't mass airflow and the truck ran worse. ive been told you gota have the same mass airflow computer
Old Jun 11, 2015 | 07:49 PM
subford's Avatar
subford
Delete Delete
Old Jun 11, 2015 | 09:20 PM
tmill28's Avatar
tmill28
what do you mean? California emissions has 2 o2 sensors and mine only has 1 and they made maf trucks that weren't California emmisons
Old Jun 12, 2015 | 07:19 AM
rla2005's Avatar
rla2005
You can't swap a Speed Density PCM with a MAF version. The pin-outs for the injectors are completely different. You need a MAF computer from a truck with the same transmission. You could get away with using one from a different engine, 5.8L versus 5L, assuming your truck has an E4OD transmission. If you have a 4R70W then you need to stick with a 5L version.
Old Jun 12, 2015 | 10:12 PM
tmill28's Avatar
tmill28
I know that's what I was saying that I used a 5.8 computer out of a 90 f250 and it made the truck worse
Old Jun 14, 2015 | 03:48 PM
meangreen92
And if it's like a Fox body Stang, the O2 sensor harness needs to match the computer. A manual transmission computer needs the harness pinned one way, and the automatic transmission computer needs it pinned another way. It should be only one wire which needs to be moved, and it's pretty easy to do.
If you throw a manual computer into an automatic car (and quite possibly truck), the automatic-style wiring will feed voltage into the computer when the starter is cranking, and that will fry it. An automatic computer is said to be OK in a manual transmission vehicle, however.
I suspect that some of the trucks might be the same way.
Huntot7
Aug 2, 2017 07:58 PM
stephen.osborne1
Mar 26, 2015 10:23 AM
timbersteel
Jul 24, 2013 06:12 PM
clong
General Automotive Discussion
Mar 27, 2005 05:58 PM
dackerma
Jan 6, 2005 08:07 PM
