Hard starting issue
Old Jan 3, 2005 | 08:27 AM
dackerma's Avatar
dackerma
Hard starting issue
Hi, my first post here. My fathers 89-f150 is having a rough time starting in the mornings. The fuel pressure regulator was bad so I replaced it. Now the truck will try to turn over on the first turn of the key, however once running it sputters and stalls. It does this for a couple minutes but once it warms up, it runs like a champ. Sometimes it will idle fine, but when I open the throttle it dies. When I race the engine up to 3000rpms for a couple seconds and let it down, it idles fine.
Any ideas what is causing this? I checked the TPS voltage and IAC valve both appear to be operating properly. Fuel Pressure is at 35psi and rises to 43psi when I open the throttle.
Thanks!
Dave
Old Jan 6, 2005 | 08:07 PM
mike L's Avatar
mike L
Welcome to FTE. What size engine does he have? You can check for trouble codes, you can have codes even if your engine light is not on. See how to check for codes at www.fordfuelinjection.com under getting trouble codes. Its easy and free. Also a Haynes manual has a ECC trouble codes section. Let us know if you find any codes.
