Sticky Temp Gauge
Old Jun 9, 2015 | 10:25 AM
sseebart's Avatar
sseebart
Sticky Temp Gauge
When I bought my 62 about a year ago, I replaced the instrument cluster with a good used unit + a new CVR for the gauges. The fuel and temp gauges have been accurate and reliable until recently. The temp gauge has started sticking at cold until the engine is mostly warm. Once it's close to operating temperature (180 on my gauge), it shoots right up. From that point on, it's as accurate as it's ever been.
It's a little annoying, as I like to watch the gauge and adjust the choke as the engine warms.
(The fuel gauge remains accurate and stable, so I think the CVR is still good.)
If I recall, the gauges are pretty well sealed up, but I was wondering if there's any way to adjust/lubricate the mechanism, or if I should just replace it.
~Steve
Old Jun 9, 2015 | 11:45 AM
daveengelson's Avatar
daveengelson
Seem to recall there's a small adjustment screw on at least 1 of the gauges, I believe fuel, not certain about the others?? I would probly start by checking connections at the gauge and sending unit to insure clean and secure, if that does not solve the problem then replace the $7 sending unit before disassembling the instrument cluster not knowing?
Old Jun 9, 2015 | 01:09 PM
sseebart's Avatar
sseebart
Good call on the sender. Ground there is good, but the sender is old and wobbly.
~Steve
bmcqueen
Jul 5, 2018 04:10 PM
75BigBlock
Jun 25, 2017 12:11 PM
49 Ford F-1
May 29, 2015 08:44 AM
alamartina
Apr 9, 2014 11:33 PM
Greezy
1978 - 1996 Big Bronco
Dec 2, 2005 03:48 PM
