gauge cluster restoration
Old 05-28-2015, 05:02 PM
49 Ford F-1's Avatar
49 Ford F-1
49 Ford F-1 is offline
Any recommendations on who to send my gauge cluster to? My temp gauge is not working, but all the other are. thank you.
Old 05-28-2015, 06:15 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Make sure the problem is your gauge, not your sending unit. The shop manual has the procedure to test the gauge with a battery.
Old 05-28-2015, 06:21 PM
49 Ford F-1
I have installed new temp sender and temp bulb. I checked the wiring it is correct. I have not seen how to check the gauge.
Old 05-28-2015, 06:26 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
The temperature gauge workings are nicely discussed in this thread: https://www.ford-trucks.com/forums/1...emp-gauge.html which references the fuel gauge test that is described in this thread: https://www.ford-trucks.com/forums/1...-question.html.
The fuel, temp, and gas gauges are the same gauge with different faces and sending units.
Old 05-29-2015, 02:51 AM
big job's Avatar
big job
big job is offline
what I do is with a long jumper - connect jumper to sender wire, go inside
turn ign. on and momentarily ground the jumper (just touch it) the temp
should go to cold if its good. If it doesnt move, put the jumper to the
sender side on the gauge and quickly ground it if now it moves then the
wire is no good. Just went through that last week & found my wire was
broken (open circut) somewhere, I just added a new wire.
sam
Old 05-29-2015, 08:44 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
It's pretty easy to change out the gauge, if that's your problem. Mid Fiftys has them.
v6lightning
03-13-2016 04:33 PM
todd jo
07-16-2014 07:44 AM
machinist91
10-01-2013 09:56 PM
ech0sh4y
03-03-2008 07:55 AM
smitty7
11-12-2003 02:56 PM
Quick Reply: gauge cluster restoration
