help identifying transmission
Old Jun 8, 2015 | 01:35 PM
anthonym92's Avatar
anthonym92
hey gents, just got a 86 f150 and well i was wondering how i can identify what auto transmission is on her. i think its a c4 but i have no idea. thanks for any suggestions
Old Jun 8, 2015 | 02:10 PM
tjc transport's Avatar
tjc transport
i ain't rite
what engine? if it is a 302, it is most likely a C-4. if it is a 300 six, or a 351, it is probably a C-6
Old Jun 8, 2015 | 02:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No 302/C4 after 1980.
1986 F150 4.9L (300 I-6) & 5.0L (302) could have either the C6 or the AOD
C6 shift dial is P R N D 2 1, has 17 trans pan bolt holes.
The AOD has an 0 in the shift dial and has 14 trans pan bolt holes.
1986 F150 5.8L (351W): C6.
Old Jun 8, 2015 | 10:07 PM
anthonym92's Avatar
anthonym92
mine is a 351w HO
Old Jun 8, 2015 | 11:05 PM
WilliamKG88's Avatar
WilliamKG88
Best way is to look at the pan shape and count the bolts.
Old Jun 8, 2015 | 11:08 PM
anthonym92's Avatar
anthonym92
will do tomorrow morning before i head to work
Old Jun 9, 2015 | 05:11 AM
DeereFord300's Avatar
DeereFord300
If the 351 is original then it's no doubt a C6.
Old Jun 9, 2015 | 09:09 PM
anthonym92's Avatar
anthonym92
yup its a c6. also ive noticed when i go from any gear to reverse there is a sudden jerk. ive checked u joints and drive shaft for play and nothing. all other gears are fine. i dont know jack about auto transmissions so any advice is appreciated
Old Jun 10, 2015 | 05:19 AM
DeereFord300
Make sure you are completely stopped before shifting which you should be doing already. It could also be worn linkage, next time it happens, mess with the shifter until you feel it directly in the detent, then see if it jerks
Old Jun 10, 2015 | 03:16 PM
tjc transport
i ain't rite
if it only does it when you shift between forward and reverse, i would say play in the rear differential.
maverick600
Jul 22, 2016 09:01 PM
shorebird
Jan 11, 2012 12:17 PM
terron78b
Jun 8, 2007 11:06 PM
blackmagic84
Sep 10, 2006 08:19 PM
jdmorg
1978 - 1996 Big Bronco
33
Jul 23, 2004 03:11 PM
