Auto trans replacement question
Old Jun 8, 2015 | 12:48 PM
Blue1978f250's Avatar
Blue1978f250
My neighbor had his trans go out on his 2001 f350 diesel. He cuts and bales hay for me so I offered to help him out. I would be replacing it on the ground am I getting in over my head? I worked in automotive for almost 10 years but I have never taken a trans out on the ground before. Any tips or things to watch for would be appreciated. Thanks.
Old Jun 8, 2015 | 03:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Make sure you can get the truck high enough to get the trans out. It's tall. You'll need a transmission jack, the transmission weighs 270 pounds.
Old Jun 8, 2015 | 08:19 PM
scottddove's Avatar
scottddove
If it's a 4x4. Take off transfer case first then take out transmission. I have done it both ways. I found it easier to split them.
Old Jun 8, 2015 | 08:42 PM
M-S-G's Avatar
M-S-G
I disagree with that one. I find it much easier to balance the tranny WITH the T case bolted to it.
It depends on the quality of your jack for sure. If you just have a $50 transmission ATTACHMENT to a regular jack - it'a a way harder job than investing even $100 in a crappy harbor freight tranny jack.
Old Jun 9, 2015 | 12:30 PM
JOHN2001's Avatar
JOHN2001
I agree with MSG. I found it easier to keep them together. What I did was used a ratchet strap on the back of the transfer case and a trans Jack. Once freed up from the engine a friend of mine steadied the back from outside the truck holding the far end of the ratchet strap. Kinda hick I know but couldn't have gone any better
I've done it both ways. My truck was also lifted 8" on 38s too so having room underneath wasn't a problem
Old Jun 9, 2015 | 01:27 PM
nlemerise's Avatar
nlemerise
Make sure you are on level ground. If this is a dirt spot, put down sheets of plywood underneath and to the side you will pull the tranny, to roll the jack on
91 Dually
Sep 10, 2011 03:46 PM
Mr.Ford 351W
Garage & Workshop
May 4, 2007 01:51 AM
worknon10s
1997 - 2003 F150
Feb 26, 2007 07:23 AM
blackcrewcab
Nov 22, 2002 08:06 PM
