Hey guys I have a long list of problems so I male them as organized as possible
Truck is sluggish up hills lacks power
-O/D light blinking off! Bad sensor?
- shifts very hard out of first and second unless I hammer the throttle
-now last after replacing all the tranny fluid filter and and gasket the transmission fluid just started pouring out of the spout in the inspection plate cover had to get towed home
do you think you overfilled it and it's now coming out the top and running down and out the spout? hows the fluid level look now? did the trans start slipping and that's when you pulled over to look and saw the fluid?
tip;
never hammer the throttle when the od light flashes.do just the opposite.run her easy home to grab codes.
Thanks guys going down to pick up a code reader I'll let you know what it says I'm thinking the front seal and the transmission took a **** and dropping the tranny to put a new seal in 5$ part 5 hours to put in in lmao
