Sponsored by: Real Truck
Blinking O/D light
Old Feb 19, 2003 | 07:10 AM
rmelki's Avatar
rmelki
Blinking O/D light
Hi everyone. Just bought a 99 F350 DRW Crew Cab and I love it. The guy before me babied it and just put 65K on it and never hauled anything so I jumped on the opportunity to buy it.
Well, I changed the oil for the first time the other night and I'm on the fuel filter and air filter next. Noticed the other night that the O/D started blinking while on interstate. Keep in mind I haven't had it more than 2 weeks. I didn't check the auto tanny fluid yet. Should have but didn't do it. It was about a quart and a half low for some reason. Dropped in 2 more and my blinking O/D light stopped.
Do you guys think I should take it in to be looked at or put on the machine to see if there is a possible transmission problem?
I called the deler and they tell me it's either a sensor or tranny going bad. This truck is almost like new and always went in for scheduled maintenance and hasn't seen a day of hard work in it's life. Hard to believe the tranny is going out. Could that O/D light just indicate low fluid and everything be ok?
Rick
Old Feb 19, 2003 | 08:28 AM
FortyFords's Avatar
FortyFords
Blinking O/D light
More than likely it was TFT sensor , noticing a higher than normal operating temp in your trans fluid due to a low condition. But there are other sensors that can cause od light flash .
You can have the dealer scan for codes on the trans looking for P**** type codes .
My suggestions is to get it serviced if under warranty and get more than one opinion on it before rebuild or replace of tranny.
Unless you trust this dealer !
Just my opinion!
Rich
we have a tranny expert here his name is Mark K.
he is are tranny guru, he'll be along shortly to help
Old Feb 19, 2003 | 08:31 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Blinking O/D light
The best thing to do is to read the code(s) that were stored when the OD light flashed. That will tell you what the computer didn't like.
If it doesn't flash anymore there is a good chance that the low fluid was the problem. There isn't a code for low fluid, but low fluid can cause a clutch to slip, and that will flash the light and set a code.
Regardless, I'd change the fluid. Has it been in there more than 30K miles? If the transmission did slip the fluid could be damaged.
Old Feb 19, 2003 | 08:47 AM
rmelki's Avatar
rmelki
Blinking O/D light
thanks for your input guys. I'll check with the previous owner
about when the last time the fluid was changed. It's still under warranty so I plan on having it serviced just to make sure and let them scan for codes as well. Thanks again.
Rick
