Some questions...
Old Jun 7, 2015 | 09:06 PM
greenf150flareside's Avatar
greenf150flareside
Some questions...
Hey everyone,
Ive got a few questions...(didn't want to have more than one thread for simple questions).
I'm having a really hard time shutting my passenger side door...(you have to slam it hard to shut it all the way)... Has anyone ever had this problem or know if there's a way to fix it? (I put some WD-40 on the striker).
Also one more question... my dash face(not on top) is very scratched... has anyone tried the dash paint? If so can you please put pictures and tell me if it works?
Thank you,
Brayden
Old Jun 7, 2015 | 09:17 PM
4x484150's Avatar
4x484150
I believe the striker is adjustable. Also, make sure the hinges arent worn out.
For the dash, there are several paints you can use. SEM makes a paint called Colorcoat, and LMC sells a similar product called Colorbond. I can't vouch for SEM, as I haven't used it. The LMC one I have used, and its a close match.
Old Jun 7, 2015 | 09:47 PM
ctubutis's Avatar
ctubutis
I've used the SEM but had it custom blended (color-matched). It's good stuff but you also first need to clean everything REALLY well, and you need good adhesion promoter and a spray gun (I got two from Harbor Failure intended for doing trim work for $12 each).
SEM is good stuff, there may already be a close-enough color available in spray cans; I'd check a local painter's supply store.
Old Jun 7, 2015 | 09:56 PM
greenf150flareside
Cool, thank you for the info...
I tried to Google the color of my dash top which is green, but no site has that color in a replacement dash top... Do you know of anywhere that sells the green dash top? And yes that's the factory, it's like a dark forest green.
Thanks
Old Jun 8, 2015 | 03:13 AM
bert cook's Avatar
bert cook
on your striker there is a little plastic sleeve that breaks off one way to repair it is cut a peice of old garden hose to fit about 1/2 long then slice it length wise to slip it over the striker then give it a couple wraps of electrical tape or go the junk yard and get a striker that still has the plastic in tact
Old Jun 8, 2015 | 03:18 AM
4x484150's Avatar
4x484150
Thanks
Wow, never saw a green interior, outside of here. Pics?
As for the dash top, it is not reproduced. NOS from ebay, Craigslist or other online sources, and be prepared to pay $$$. Only dash covers are available otherwise, and I would imagine green is hard to find.
Old Jun 8, 2015 | 05:34 AM
Ken Blythen's Avatar
Ken Blythen
Thanks
It sounds like it might be Teal, which is what my interior is too. It's not very common, so most of the repro part suppliers don't do it.......but like ctubutis said, the aerosols can be color matched to suit.
Old Jun 8, 2015 | 07:20 AM
WilleyJoe.62's Avatar
WilleyJoe.62
Ditto on bert's striker "padding". I thought my door rattle was going to drive me crazy, and they'd never close completely. I used 1/2"x5/8" PVC, also cut lengthwise, and inserted needlenose pliers to act as a spreader; then I was able to snap them onto the strikers. Instant fix --
Old Jun 8, 2015 | 07:39 AM
greenf150flareside
I'm going to try fixing the door today thanks for the info.
As for the interior I will try and get some good pictures up today.
Thanks
Old Jun 8, 2015 | 07:50 AM
roboto65's Avatar
roboto65
Make sure to grab the door while it is open and lift it up this will tell you weather your hinges are good or bad any play and the hinges or bushings are worn.
Old Jun 8, 2015 | 08:31 AM
ctubutis's Avatar
ctubutis
The interior color code is the second character of the BODY code at the bottom of the certification label on the driver's side door jamb, it might help you in coming up with matching paint.
Old Jun 8, 2015 | 09:13 AM
JordanL91's Avatar
JordanL91
Great Fix Willey!
Vince79vette
Dec 11, 2019 10:22 PM
dunnerjeff
Mar 19, 2015 09:44 PM
fordboy300
35
Feb 11, 2015 05:56 PM
cujo8
Appearance & Dress-Up
Jun 24, 2006 06:37 PM
LARIAT 85
Jul 8, 2005 01:28 AM
