2001 F450 problem...
Old Jun 6, 2015 | 03:35 PM
Concrete guy josh's Avatar
Concrete guy josh
I have a 2001 F450 7.3 chassis cab with just over 100k. I have a new problem...
So far on two different occasions the service engine came on followed by a loss of power under a load and white smoke from the exhaust. Took it to the shop the first time, they determined it to be a dirty air filter, which seemed odd since it just happened all of a sudden. They changed air & fuel filter, problem gone- for two weeks. Came back yesterday, any ideas?
Old Jun 6, 2015 | 04:09 PM
Pikachu's Avatar
Pikachu
The first thing I'd suspect is low fuel pressure.
Old Jun 6, 2015 | 04:10 PM
Concrete guy josh
Low fuel pressure intermittent?
Old Jun 6, 2015 | 04:15 PM
schlepprock250's Avatar
schlepprock250
Did the 01 f450 chassis cabs have the metal tank delam issue? Maybe...
Old Jun 7, 2015 | 02:51 AM
djed's Avatar
djed
My 01 F-350 cab and chassis did have a tank that delaminated and plugged up my fuel system. Not sure about the 450 but I suspect they had the same 40 gallon rear mounted tank.
Old Jun 7, 2015 | 05:02 AM
Tugly's Avatar
Tugly
You are describing the symptoms of low fuel pressure, and the SES light is usually ICP-related - because the ICP has nothing but air to push against. This causes very low atomization of the fuel, and it pretty much comes out the tail pipe as vapor - like a demonic humidifier. The truck will also buck, shake, and knock, giving the appearance of an engine trying to fight its way out the hood.
The fuel filter might have solved the problem last time, if your fuel tank is steel and the interior coating is delaminating - it sloughs off and clogs the fuel filter. If you have a plastic tank, the fuel line quick-connects and internal screens are suspect. If you don't have cottage cheese in your fuel filter, remove the outlet hose from your fuel pump and blow air into it with a compressor and a rubber-cone nozzle to clear all screens. If the problem clears up and later returns, you are due for a Hutch mod. Info on this abundantly available here with a search... I think I even put a link in my signature.
Old Jun 7, 2015 | 11:26 AM
Concrete guy josh
Thanks Tugly,
When I pulled the fuel filter last time it had, what looked like, sand in it... Does this play into your delam theory?
Old Jun 7, 2015 | 12:52 PM
izzybird's Avatar
izzybird
If you have the steel tank it is almost certainly delaminating, the fix is to replace it with a poly tank. My buddy didn't have the funds to buy a replacement so we dropped and "cleaned" the tank, eliminated the mixing chamber in the tank, and installed the filter in this pic I borrowed from Tugly before the pump. He's run it this way for over a year and just cleans that pre filter every couple months.
Old Jun 7, 2015 | 12:55 PM
izzybird's Avatar
izzybird
Blowing some shop air back to the tank like Tugly said will generally let you know if that is where the fuel restriction is cause it will free up some flow and run tons better..till it clogs back up.
dennisw1mac
6.7L Power Stroke Diesel
Oct 17, 2016 08:03 AM
allisfan
Apr 27, 2016 10:14 AM
tomf52
Jun 30, 2008 07:35 PM
bigvic92
23
Jul 10, 2006 10:48 AM
dpbeale
May 20, 2006 07:41 AM
