Sponsored by: Real Truck
2002 5.4 P1289 code
Old Jun 6, 2015 | 07:57 AM
wvabeer's Avatar
wvabeer
2002 5.4 P1289 code
I have a E350 5.4 with 200,000 miles and it ran great before winter, this spring I fire it up and it got a miss I drive it anyway it starts to clear up and now the 1289 code. Everything looks fine coolant engine temp. I wonder if you can bypass the Cylinder Head Temp sensor. I am thinking the engine management is causing the miss to cool the engine. What do you think?
Old Jun 6, 2015 | 02:01 PM
DavidB's Avatar
DavidB
The P1289 code is NOT engine coolant temp code. It IS cylinder head temp code.
Possible causes
- Wrong thermostat
- Not at operating range
- Engine overheated
- Low engine coolant level
- Faulty Cylinder Head Temperature (CHT) sensor
- Cylinder Head Temperature (CHT) sensor harness is open or shorted
- Cylinder Head Temperature (CHT) sensor circuit poor electrical connection
When is the code detected?
The Engine Control Module (ECM) detected the cylinder head temp above or below expected values
Troubleshoot accordingly.
Old Jun 16, 2015 | 04:20 PM
wvabeer's Avatar
wvabeer
Can I short this out or remove it?
Old Jun 17, 2015 | 07:28 AM
DavidB's Avatar
DavidB
NO. Troubleshoot and repair it.
gint279315
1997 - 2003 F150
Oct 28, 2021 09:05 PM
Rob Thomas
Modular V8 (4.6L, 5.4L)
Jun 17, 2017 09:42 AM
cory5517
2004 - 2008 F150
Jul 6, 2016 02:53 PM
enriched&beyound
1997 - 2003 F150
Jun 12, 2010 01:51 PM
Fredster
Feb 7, 2007 08:05 PM
