Sponsored by: Real Truck
Help with oversize tire options
Old Jun 16, 2015 | 10:33 PM
MXZ1983's Avatar
MXZ1983
Hi all,
I have a 2015 SD PSD RCLB XL truck with a Western Ultramount MVP plow on it. The stock tires being 245/75/17 look a little goofy and small on it.
Can you guys tell me what size I could go to, just slightly bumping up the size and not rub at all? I will not be doing any leveling kits or anything of that sort, just looking for a tire that will fit and work/look better.
Thanks in advance.
Old Jun 16, 2015 | 10:47 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
285/70R17s looks fine. I wouldn't go up into the 305mm+ range on stock 7.5" wide rims. Rubbing won't be a concern if you stay under approximately 34x11, that's roughly the largest stock tire. You can put larger tires in, but under that size on stock wheels, no rubbing should be almost a guarantee.
Old Jun 16, 2015 | 11:09 PM
Omega Man's Avatar
Omega Man
I'd stick with load range E no matter what size you pick.
Old Jun 17, 2015 | 05:18 AM
NYCruiser's Avatar
NYCruiser
I swapped those same tires/rims out for the set listed in my signature. No issues. Check out ebay for some stock take-off tire/rims. Plenty for sale if you want some nicer stock rims too.
Old Jun 17, 2015 | 05:20 AM
redford's Avatar
redford
FTE Leadership Emeritus
Most tire shops won't mount anything wider than a 285 on the stock 17 inch rims.
Old Jun 17, 2015 | 05:54 AM
MXZ1983's Avatar
MXZ1983
So a 275 70 17 would fit just fine?
Old Jun 17, 2015 | 05:56 AM
redford's Avatar
redford
I run a 285/70R17E on mine without any issues.
Old Jun 17, 2015 | 09:08 AM
texastech_diesel
Token Redneck
Yes, but they're basically 1/2" taller, and 1" wider, not a hugely significant difference. They'll still look small.
mrrish79
Feb 2, 2021 09:35 AM
deere55
Jan 4, 2011 08:06 PM
AllMuscle03
Jan 31, 2010 06:27 PM
threetago
2004 - 2008 F150
31
May 22, 2004 01:26 AM
Ford1TonsRock
Nov 14, 2003 09:39 AM
