Sponsored by: Real Truck
Upfitter wiring question
Old Jun 4, 2015 | 11:31 AM
smarty39's Avatar
smarty39
I currently have Aux2 hooked up to my on-board compressor and it works like a charm...so I'd like to think I know how the wiring works for the upfitters haha.
This weekend I installed an electronic solenoid valve for my slip-tank so I can fuel up on the go. The valve is 110V AC and had two wiring leads of the same color so I assumed either/or could be used for power and the other for ground. I wired it all up running a power lead from Aux3 back to the valve and grounded the other wire to the body. To my surprise...no power! Can a 110V AC valve not be used in this application or is my wiring simply messed up/not making contact?
Any insight is appreciated .
Thanks!
Old Jun 4, 2015 | 11:59 AM
RightWingNutJob's Avatar
RightWingNutJob
Thumbs down
Upfitter switches are 12 Volts DC - Direct Current.
Your Valve runs on 110 Volts of AC - Alternating Current.
The switch is putting out the wrong type of Electricity.
You can either get a new 12 Volt DC-actuated Valve, or put a DC-to-AC inverter on the output of the Upfitter switch to send the right kind of power to your AC Valve. ( You'd also need to know the Current Rating, and possibly the Inrush Current of the AC valve in order to get the proper sized Inverter.)
(Not sure if being hooked up to DC for an extended period could've damaged your AC valve's actuator.)
Old Jun 4, 2015 | 01:33 PM
smarty39's Avatar
smarty39
Kinda what I figured after doing some reading...guess it was too good to be true to have this valve laying around and think it would work.
Thanks for reply...off to find a 12V valve
caravaggio2000
Jun 10, 2019 08:13 AM
F0rdF0rever
Jul 3, 2018 04:35 PM
bigperm2
Feb 28, 2016 06:53 AM
whits
Jun 28, 2007 02:59 PM
86diesel-
Mar 30, 2006 08:26 PM
