CDR Valve
Old Mar 29, 2006 | 03:46 PM
86diesel-'s Avatar
86diesel-
CDR Valve
I am servicing my CDR valve and I was wondering how it works. I have it all cleaned up. If I shine a light into either of the ports I can see the light through the other port. Is this normal?
Old Mar 29, 2006 | 06:56 PM
IHdieselfan's Avatar
IHdieselfan
Yes it is normal, if you can see light it needs to be replaced.
Old Mar 30, 2006 | 09:32 AM
86diesel-'s Avatar
86diesel-
The CDR valve I pulled off has an AC stamp in it. I guess that means AC Delco? Could this be the wrong valve for this engine or could it be like many other parts and be the same part used for other engines?
Old Mar 30, 2006 | 10:42 AM
bcford6.9's Avatar
bcford6.9
I cleaned my CDR, first time since I owned the truck. Previously I have noticed blowby comming out of the dip stick tube, I will see if cleaning CDR valve will help?
Old Mar 30, 2006 | 07:01 PM
86diesel-'s Avatar
86diesel-
I know someone suggested replacing my CDR valve but I wanted to do a little test before I did. I installed it back on my engine and started it up. I then looked down into the intake while it was running and noticed that there was a noticeable amount of crankcase vapor flowing in from the CDR valve. Should the CDR valve eliminate all vapor from entering the intake or will it let some in? I just want to make sure I need the valve before I buy it. Thanks.
Old Mar 30, 2006 | 08:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
At idle it should be taking it all in. What the CDR does is closes down at higher RPM's so the engine don't suck the oil out of the rocker cover.
kitsapcountychopper
Oct 23, 2018 12:06 AM
ineedhelp92
May 4, 2013 12:04 PM
newr
17
Aug 5, 2009 10:08 PM
CowboyFromHell
Jul 16, 2008 05:52 AM
bronco460
Sep 2, 2003 10:36 PM
