2003 6.0 Cold Start Issue
Old Jun 2, 2015 | 04:05 PM
acramerjr1's Avatar
acramerjr1
Hi guys, long time viewer first time posting. I want to thank everyone in advance for all of the info I have learned about concerning the 6.0, always very helpful. I am a farmer from Louisiana and would appreciate any advice or direction someone could give me. I recently deleted the EGR, rebuilt the oil cooler, rebuilt the turbo, updated the turbo drain tube, replaced the water pump, changed the ICP sensor and pigtail and added a coolant filtration system. The truck fired up pretty quickly after the job was complete but about 2 days later I started having a problem where if the truck sat overnight, it would start, die, start, die, start then run fine for the rest of the day. Next morning same thing. I pulled the IPR to see if the screen was dirty but it was clean. I am at a loss where to look next, any suggestions would be great. Thank You.
Old Jun 2, 2015 | 04:31 PM
mikeysfun's Avatar
mikeysfun
FICM voltage?
Old Jun 2, 2015 | 04:34 PM
Maxium4x4's Avatar
Maxium4x4
If you have something to scan the engine and give us information that would help. I have the Torque App on my phone.
Old Jun 2, 2015 | 04:41 PM
acramerjr1's Avatar
acramerjr1
48V, never drops below 47.5v while cranking
Old Jun 2, 2015 | 07:00 PM
WatsonR's Avatar
WatsonR
Could be dummy plugs or standpipe. That one doesn't have the STC fitting, you probably have a leak in the system somewhere.
Check the drain back valve under the oil filter.
Old Jun 3, 2015 | 07:50 AM
acramerjr1's Avatar
acramerjr1
I removed the oil filter and Held the drain back valve down while cranking and the filter reservoir filled up pretty quickly
Old Jun 3, 2015 | 08:03 AM
WatsonR's Avatar
WatsonR
what are the ICP numbers at KOEO, idle and 2500RPM? Specifically when it doesn't want to run, maybe first start, second start and third? Trying to see what your loosing when it dies. Also the IPR %'s
This could be a fuel issue. Pull the upper fuel filter, get a helper to do the key while you watch the fuel bowl fill. It should fill about as fast as you can say...I'm ready, they hear you yell stop, under 5 seconds. Do you have the blue spring mod for the fuel pressure? Last time you changed fuel filters?
Old Jun 3, 2015 | 09:31 AM
acramerjr1's Avatar
acramerjr1
I will get those numbers for you when I get back next week. I did do the blue spring upgrade and I changed the fuel filters 1 week ago. I will also check the fuel bowl filling as you stated. Thanks for all your help so far
Old Jun 5, 2015 | 09:49 AM
acramerjr1's Avatar
acramerjr1
Update: I read a post by Cheezit that said to place the truck in a nose down position overnight. I tried this and the truck fired right up and never died. So know I know that my hpop is bad and will be changing that out soon. Is there anything else that I should do while changing out the hpop while I have the truck apart. I rebuilt the oil cooler about 2 months ago along with updating the turbo drain tube. Thanks in advance for your help and suggestions
Old Jun 5, 2015 | 09:59 AM
WatsonR's Avatar
WatsonR
Stand pipe and dummy plugs.
Old Jun 5, 2015 | 04:43 PM
Rellick's Avatar
Rellick
Get the dieselsite HPOP. I will when mine goes out.
http://www.dieselsite.com/2003-20046...lpumphpop.aspx
Some also recommend swapping the HPO tube (3c3z-9t288-aa).
I'm also swapping to an '04.5+ intake manifold to make that hpop/icp/ipr work easier in the future.
Old Jun 7, 2015 | 04:12 PM
acramerjr1's Avatar
acramerjr1
I was under the impression that the stand pipes usually don't have problems with the 03 models
Old Jun 7, 2015 | 08:21 PM
dannyboy950's Avatar
dannyboy950
The 03 has a different type standpipe and no dummy plugs. It has a single log oil rail on each side. Dummy plugs came out on the 04 with the implementation of the wavey oil rail.
Old Jun 8, 2015 | 01:47 PM
acramerjr1's Avatar
acramerjr1
Thank you for your information
allenhillview
Feb 2, 2018 05:27 AM
FLO98
May 11, 2016 10:50 PM
spotshot
Apr 22, 2016 05:45 PM
powrstroke
Jan 26, 2015 04:32 PM
Bmac65459
Jul 21, 2011 06:25 AM
