My 6.0 has a little trouble getting started
Hi guys and gals, I just bought my 2007 f350 6.0 2 weeks ago, on cold start it's a little fussy getting started, but once warmed up I have no issues at all! Any ideas what it could be and is it expensive. When I bought the truck he had $1000 worth of work done, cold start issue. Thanks in advance for help
If it's fussy, you need a to give ita bottle to quiet it down.
What I'd recommend: AR9100 Nanoborate Friction Modifier | Archoil
Use it with Synthetic 5w40^^^^^
Do you happen to know your flash? (Example VXCF4X3, VXCF9XX)
Depending on your strategy, you may not have an inductive heating FICM.
Ok I know the guy I bought the truck off of they did think that there was a issue with the FICM but that was not the case, but may be the case now! Who knows. And this nanoborate friction modifier where can I get that? O Reilleys? This is my first diesel, I am a handy woman. I have to change the oil so I think I will pick some of this ar9100 up. I Donot know what"flash" is sorry I'm green to diesels, but leaning very fast! Thanks for the info! Hopefully it's as easy as that!
Amazon or from another internet vendor.
Before you get overwhelmed, here's a great read about the gauges everyone is going to tell you to get:
https://www.ford-trucks.com/forums/1...eral-info.html
I think I have a similar issue. My truck starts without incident, but if I ask for power within 2-3 minutes of startup, I get low torque. Putting my foot harder into the accelerator seems to induce misfires.
Let the truck idle for 5 min before moving, and it feels fine.
I run homemade biodiesel, which is higher viscosity. That may be a contributor.
Anyway, within the last 1000 miles I changed the oil. It was Rotella T6 5W40 (my typical winter oil). I put in Rotella T 15W40 (my typical summer oil).
Can I add in the AR9100 at this point or am I significantly better off to do this with fresh and/or lower viscosity oil?
To be fair, I should also run a tank of petrodiesel through it to see how much of it is fuel viscosity...
regards,
Rory
mad dog musher
1999 to 2016 Super Duty
09-18-2018 05:10 PM
05pstroke6.0
12-18-2007 08:49 PM
powerstrokedieselboy
02-04-2004 04:12 PM
