C6 overdrive
Old Jun 1, 2015 | 08:10 PM
doug51f1's Avatar
doug51f1
C6 overdrive
Anyone know where I can find an overdrive unit for a C6? I've got a 69 F250 with 390/C6. 8 mpg is tough to stomach.
Old Jun 1, 2015 | 08:12 PM
HIO Silver's Avatar
HIO Silver
Gear Vendors Overdrive:
https://www.gearvendors.com/f2wd3s.html
Old Jun 1, 2015 | 08:42 PM
doug51f1's Avatar
doug51f1
Thanks. I was hoping for something a little less expensive. I'll certainly go that route if nothing else turns up.
Old Jun 1, 2015 | 08:48 PM
HIO Silver's Avatar
HIO Silver
Well, you asked and I provided. I swapped a NP435 with a TKO... not cheap but I was recently rewarded with 17 MPG on a 60-mile test loop.
Alternatively, drop to a numerically lower gear like a 2.75 or 3.00. What rear gear ya running now?
Old Jun 1, 2015 | 08:51 PM
orich's Avatar
orich
Keep the speed down to 50 mph and ya might get 10/11 mpg.
Most all new owners like putting the gas pedal down more then needed to get the truck rolling good..
Dual exh pipes can help keep the tires aired up. A good tune up all gets to some added points for better mpg.
Orich
Old Jun 1, 2015 | 11:05 PM
351Cleveland C4's Avatar
351Cleveland C4
High rearend ratio, 235/85 tires, headers and dual exhaust. You'll get the mid teens.
Old Jun 2, 2015 | 05:04 AM
jowilker's Avatar
jowilker
Sorry bub, but them ol 250s and MPGs don't comprenda. But should need the mpgs towed you have the truck to do it.
John
Old Jun 2, 2015 | 09:17 PM
doug51f1's Avatar
doug51f1
Well, that's true.
Old Jun 3, 2015 | 07:06 AM
f100today's Avatar
f100today
I think there is a e4od swap? But that's not cheap either. GV is probably your best bet. I've seen used ones out there.
Old Jun 3, 2015 | 07:51 PM
F&M's Avatar
F&M
My 66 M100 has a C6 and gear vendors.A 3:89 rear set should bring me in at 3:04 or so in the high hole.I'm hoping for high teens or 20MPG.I can't wait to give her a try.
Old Jun 3, 2015 | 11:12 PM
orich's Avatar
orich
Better get yea a vacuum gauge meter when using any kind of o/d for max mileage. If not you'll fall way short of your goal post.
Orich
Old Jun 4, 2015 | 12:06 AM
351Cleveland C4
Orich
For sure. My AOD turns my 4.11s into 2.75s. Big jump. If I'm easy I can cruise at around 15".
Old Jun 4, 2015 | 05:30 AM
willowbilly3's Avatar
willowbilly3
I think 3.55 is the longest legs you can get for a Dana 60, or that Ford put in anyway. With a 30-31 inch tall tire, 3.73s are a pretty good compromise. I've had several F250s with 390 and 3.73s and always ran around 12-13 mpg. In the old days of better gas I had several F250 4x4s with 360s that always got 12-13 on 4.10 gears (55 mph speed limit days)
Elcheapo overdrive- I had an old hillbilly neighbor in Alaska who put a T85 in his rear driveline on a mid 70s F350 4x4 crewcab.
Old Jun 8, 2015 | 03:53 AM
Cracker289's Avatar
Cracker289
Somebody makes an adapter kit to put a GM 700R4 behind a Ford FE, that might be the way to go if you're on a budget. Buy the adapter and find a used 700r4 locally to stick in there and you got OD.
Old Jun 8, 2015 | 09:00 AM
TeachNlive4ever's Avatar
TeachNlive4ever
I've looked into the Gear Vendor and the 700R4 adapter business. the bottom line is about the same. $3K!
There is an adapter for FE to 700R4, I forget who makes it(google it), but i recall it being $800. Rebuild trans.,starter, rebuilt drive shaft,Wire kit so the 700R4 will work, blah blah blah, $3K!!!
Next time i get rich, I'm rolling with gear vendor..
jayro88
23
Jul 5, 2014 11:39 PM
'78f350
May 21, 2014 11:44 PM
drunkdave
1978 - 1996 Big Bronco
Aug 10, 2010 09:43 PM
Chris_ce
Aug 2, 2003 08:54 AM
79_custom
Jul 15, 2003 03:32 PM
