EGR issue?
Old Jun 1, 2015 | 05:28 PM
ab1500's Avatar
ab1500
EGR issue?
So ive done all types of test. Hair dryer test had icm tested ohmed out each injector, new plugs wires cap rotor pretty much have this thing narrowed down to either a distributor issue or egr. The reason I think its egr based is because my fuel millage changes alot. I've got an extremely missing problem only when my trucks hot. I put headers and straight piped with a cat delete andyheres a tube ran to egr that connects to the exhaust yeah well I plugged it. So I'm thinking that's my issue. But I don't know. My trucks a 1992 5.0 302 f150 flareside any help is well appreciated.
Old Jun 1, 2015 | 05:40 PM
timbersteel's Avatar
timbersteel
I don't know of any 302's where the EGR connects directly to the exhaust. The 302 setup is pulled from the intake manifold. The 300, 351, and perhaps the 460 got the EGR pipe connected to the exhaust.
Can you post a pic?
Have you checked for codes?
Old Jun 2, 2015 | 08:10 PM
ab1500's Avatar
ab1500
I'm not sure what it is I'm almost positive its an egr tube if not what could it be I never traced it down just was told it was egr and my fix if it was sucking to plug it if not leave it open the truck bogs down and looses power when its hot and when I unplug the egr sensor it has different symptoms but the problems still there just nit as bad plug egr back in during the issue and it gets 10x worse.
Old Jun 2, 2015 | 08:55 PM
Conanski's Avatar
Conanski
The tube that connects to the exhaust near the cat is for air injection and you can't plug it, otherwise it's likely the air that would go to the cat will get forced into the exhaust upstream of the O2 sensor and that will cause driveability issues once the motor goes into closed loop.
AAubinoe
Jul 31, 2014 11:28 PM
jamesgoodhue
Dec 23, 2009 10:05 AM
aadams47
Sep 8, 2006 04:33 PM
quadzjr
15
Dec 8, 2005 04:36 PM
oricle
Apr 5, 2005 10:33 AM
