engine /Trans mount
Old May 31, 2015 | 03:20 PM
newguy399's Avatar
newguy399
engine /Trans mount
Hey guys just put my 292 with what I belive is a t-98 4speed.
The front engine mount looks to be about perfect, but the Trans mount ears are about 6 inches short of the original cross member. Do I have to make or by a new cross member to mount the Trans in the truck it's a 1956 f100. Motor Trans is out of 1963 f100
Thanks
Dan
Old May 31, 2015 | 03:38 PM
raytasch's Avatar
raytasch
Believe Nothing
The 56 will have a single point mount in front. The rear clutch housing is the rear engine mounts. Pictures, measurements of your frame?
Edit: Just took a measurement on my 56 F350 and found about 32 1/2" from the front center mount to the driver side clutch housing mount bolt. I checked the clutch housing from an F100 and the the block mount surface to the engine mount is the same, about six inches.
Old May 31, 2015 | 03:55 PM
newguy399's Avatar
newguy399
Ray I will try and get pictures tonight when I get home .the front mount looks like it will work, but does the Trans mount with the side ears or one single mount in back
Old May 31, 2015 | 04:00 PM
GLR's Avatar
GLR
Trans should mount with the side ears on the bell housing. No Mount in the rear of trans. At least it is on my 54 and a 64 292 w/T98.
Old May 31, 2015 | 04:19 PM
raytasch's Avatar
raytasch
Believe Nothing
I believe your clutch housing, bell housing may be different. Here is one from a 1956 F100, total depth from engine to transmission is ~ 7 inches..
Old May 31, 2015 | 05:48 PM
newguy399's Avatar
newguy399
Yep that looks just like the original one off my 272...GLR how did you mount your engine/Trans in your 53. I plan on doing it in the 56. Did you buy the mounts for your Trans and did you use the original mounting holes in the front
Old May 31, 2015 | 06:02 PM
GLR's Avatar
GLR
Original mounts in the front. When I got it it had a crashbox 4 spd hooked to the 3 spd bellhousing with 3 1/2' "adapter plates". I installed a regular 4spd bellousing and T-98 using the original bellhousing "ear" mounts. If I was back in NY I could compare the bellhousings.
Old May 31, 2015 | 06:15 PM
bigwin56f100's Avatar
bigwin56f100
I'll bet your 56 was originally a 6 cyl truck and you are missing the v-8 cross member up front
Old May 31, 2015 | 07:54 PM
newguy399's Avatar
newguy399
Big win did the f250 come with a 6 cylinder? And there should be 3 cross members right,
Just answers my own question. .I am missing the v8 cross member
Old Jun 1, 2015 | 08:47 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
PM BigWin56F100 he may have what you need. Or ask on here as many have removed them to install other types of engines.
ftlover90
13
Apr 17, 2017 06:33 PM
Walwal44
Mar 25, 2014 12:43 PM
Rig-rat
Jan 25, 2013 01:06 AM
raerjim
Sep 23, 2011 09:42 AM
66beater
Nov 6, 2005 02:15 PM
