Transmission questions
Old Nov 5, 2005 | 09:18 AM
66beater's Avatar
66beater
Lightbulb Transmission questions
I'm Swapping from a 3 on the tree to a T98. I have the correct bell housing for the swap, and few of the parts I need, but one glairing problem still faces me.
The 3speed has its mount on the rear side, with a cross member. the T98 has no place to bolt a mount to it.
I can move the cross member easy enough to where ever it needs to be, but how to I attach a mount to the transmission?
The truck is a 66 F100 LWB, 2wheeldrive with a 352
Old Nov 5, 2005 | 10:44 AM
killerkjn's Avatar
killerkjn
The t98 transmission just hangs off the back of the engine with no cross member. I have a 64 with a 223 6 cyl. with a t98 and mine has no braces.
Old Nov 5, 2005 | 11:47 AM
obsa's Avatar
obsa
66, your engine trans combination uses a three point mounting system with two mounts on the engine and a trans mount. A 64 or earlier system uses a three point system where two mounts are on the Bellhousing and a mount in front of the engine. I really cant answer your question but with your mount setup as is you cant just let the trans hang off. I sure someone has the answer here.
Old Nov 5, 2005 | 06:05 PM
Sam_Fear's Avatar
Sam_Fear
Would a T-18 or T-19 have the correct mounts? Just thinking if you went with one of those you wouldn't get stuck with that 'granny' 1st gear.
Old Nov 6, 2005 | 08:42 AM
66beater's Avatar
66beater
Actualy, I wanted the Granny gear. I've run into too many situations were nothing but a lower gear will do, from backing my truck through the 7 and a half foot gap between the house and the fence, up hill, with 2000 pounds of topsoil in the bed, to fighting Dallas traffic, were first gear is far too high for the 1 MPH trafic speeds on HWY 75.
An Automatic would probably have been a better option, but I enjoy driving stick.
It looks like the bell housing has mounts on it, but the motor it came from had its mounts on the front of the block. Mine are in the normal place, mid block. If I fabricate something to hold mounts at the bell housing, will they be too close to the motor to be effective?
Old Nov 6, 2005 | 09:27 AM
Redmanbob's Avatar
Redmanbob
I would think maybe having a bracket of aluminum migged onto the tranny in the right place to line up with you existing cross member if possible or wherever possible might do the trick. But welding on a tranny ? I dunno if it might hurt the tranny.. I doubt it..
I do think the "*****" of that motor need a brace on the tranny..
Old Nov 6, 2005 | 11:44 AM
hiball3985's Avatar
hiball3985
sounds like the trans pre 65, so you will also run into input shaft problems, you need a np trans from 65 up to swap
Old Nov 6, 2005 | 12:53 PM
banjopicker66's Avatar
banjopicker66
The T-98 was used at least to '66, if not later. It should (operative word here is "should") have a spot to bolt the tranny mount to. Usually, it is a flat spot, with two hold for bolts. As a matter of fact, it should look the same as what is on your 3-speed transmission now.
Obsa is correct, '64 and earlier use a different mounting system than your '66.
Your '66 has a transmission crossmember for the transmission to bolt to. You need that mount point to keep the engine/transmission combination from skewing or yawing sideways, especially under load.
HiBall is also correct, that an NP 435 will work well. The T-18 also has the granny gear of the T-98 and NP-435. (Maybe not the exactly same ratio, but at that low, who cares!)
Perhaps you have an earlier transmission which was not made with that mount point??
Old Nov 6, 2005 | 01:58 PM
66beater's Avatar
66beater
As I was told when I bought it, it originaly came out of a 67 4x4 (but it has no flange for a transfer case, so I don't know) that used a mount on the bell housing as well, or so I'm told. The bolt pattern and starter clearance seem to be for an early FE. There doesn't seem to be a flat spot on the back side of the transmission to bolt anything to, but I may not be looking at it right. when I got it, it was on the back of a 390 bolted into a 60 f100 with home made engine mounts of angle iron and half inch flat plate.
Anyone have a picture of one with a mount?
Whats the problem associated with the input shaft?
Old Nov 6, 2005 | 02:15 PM
hiball3985's Avatar
hiball3985
without pics its hard to tell, but the 64 and earlier trans just mounted to the bellhousing, there was no mount for the crossmember, sounds like the 390 was bolted to the original 4 spd, if thats the case, its input shaft is longer and won't work with the 65 and later bell housing as far as I know
JIM
mcali2
May 11, 2014 07:40 AM
Ford F834
Mar 18, 2012 11:31 PM
Corrupt Silence
19
Feb 23, 2011 06:34 PM
fatcathp
16
Oct 2, 2009 05:43 AM
jmono
May 12, 2007 02:15 PM
